P1000 SOLVED - Check engine 2-9 or 29-1 IAT high idle rough idle
tdhanses
tdhanses
1,044
3,553
Kansas
Do not use "Crimp" connectors that is a recipe for disaster. They will break at the crimp, sooner or later. There is only one proper way to attach a new pigtail, that is solder the joints and insulate with high quality heat shrink. Use rosin core solder, not acid core. Use .032 Multicore or silver bearing solder. Also clean that plunger and the bore of the throttle body to remove ANY signs of dirt, varnish or carbon.
Don’t think he is pigtailing, looks like a new connector with the inner crimp connectors.
67,223
IACV connector wire breaks are becoming more common.
The break is not visible and is inside the insulation of the wire usually right at the connector head. Just like the fuel injectors.
There have also been several reports of the MAP connector having the same issues.
2018GMC
2018GMC
174
356
AZ
This is why I ordered the plug without wires. I wanted to keep factory look and not the white wires plug offered in the store. Looks like you crimp and could put some solider in these connectors after running wires into new plug.
1628092179257
2018GMC
2018GMC
174
356
AZ
Good point. On a positive note I like the looks of the pioneer. Love the dual clutch transmission, paddle shifters, 3 in front seat and ability to seat 5 or haul stuff in a short wheel base.
I’ll write my fusterations to Honda (they prob won’t care) but I’ll feel better!
208,729
Go ahead and replace your injector plugs while your at it there next.
Reactions: Lady01 and 05Willys
Lady01
Lady01
192
488
Midland Michigan
Thanks HondaSxS, this is some of the best information... So, I am curious, why do you suppose there are issues on these wires just outside of the harness connector/crimp...? Do you have any theories?
WagginTail
WagginTail
1,585
5,880
SC
I think you need a special crimping tool for those. Delphi style maybe? If so you can find one on Amazon
2018GMC
2018GMC
174
356
AZ
Fixed! Crimped new connector on and check engine light is off along with normal idle. Cleared check engine light and restarted a few times - all good.
I checked fuel injector wires, wiggled them and no change in idle. I electrical taped up all the plugs to wires on that harness to give them some extra Rigidity.
DE5441C3 9DE1 4473 8D47 0A34CCDD21FD
C287E12A 732B 4A9C 9015 CEAD370BAEE7
23A6F97E ECAC 496E BB36 F6E508B17760
2018GMC
2018GMC
174
356
AZ
Woo-hoo.
Did you find the break?
Yep, wires looked fine but wouldn’t ring out when tracing them from IACV plug to grey computer plug under driver seat. Break was right where the wires enter the IACV plug. You can see on the far right wire when I pulled on it it broke. But before this 2 of 4 wires wouldn’t ring out even though they looked fine. Wire broken inside insulation.
968F2EDB E848 4601 AA49 F8C20747D1A8
Lady01
Lady01
192
488
Midland Michigan
Great investigative work! Thanks for sharing!
