P500 Soundbars....need help
rocmar
rocmar
4,741
5,778
4 CORNERS
Sound stream
8"...150 watt
Amp....
Turns all sound bars
....into wat you thought you
....bought.
Don't matter how many...
Speakers in the bar you have. .
Sounds...like AM radio....
Need at least 8"bass speaker
20170112 124527
Reactions: trigger
rocmar
rocmar
4,741
5,778
4 CORNERS
That's a fact...
Sound bars...biggest
Speaker..which they
Call...mid range...3"diameter
Does not & will not produce
....bass..
Just sayin...
rocmar
rocmar
4,741
5,778
4 CORNERS
Got alot of vids..
Of stereo. .but can't
Finger out..u tube
Ems-Cam
Ems-Cam
252
336
Alberta
Sound stream
8"...150 watt
Amp....
....bought.
did you build your own then or is this an addition to one you had? A sound system is on my list, but the prices of the ready to install ones scare me.
Reactions: rocmar
rocmar
rocmar
4,741
5,778
4 CORNERS
Yep...
4 speaker...Armor sound bar=$324.....
8"....spearker/amp..=$120
Music wise...is soundbar worth that....NO
being able to mount on rear roll bar.......yes
So...I put 2 things together...
So yeah...that's a build
rocmar
rocmar
4,741
5,778
4 CORNERS
Spendy,,,
But one time deal...
Good ride...turns
Great...with tunes
Limited places to mount.....
Also..was a soundbar sell...
196,414
That's a fact...
Speaker..which they
....bass..
Just sayin...
A 3" can produce bass, just not much for very long. Had a buddy that hooked a couple Sony 3" up to a 100w amp once, they cranked for about 15 minutes, then never worked again. They put 6" in my SSV Works, way more money though.
You gotta figure out how to post those vid's. Check out @PistonHonda 's thread about his new camera, I wrote up a basic How To.
rocmar
rocmar
4,741
5,778
4 CORNERS
Hope I get help
...posted fine as a vid..
For everyone else
rocmar
rocmar
4,741
5,778
4 CORNERS
If ya ain't got at least
A 8" bass spearker...
IMO...your just a
...AM sounding radio
Reactions: pFive
196,414
Finishing up a room addition on the house right now so I haven't had any time to mess with the P5. Even though that's all I can think about as I'm working. Have some stuff waiting to go on and even more in my head.
One of the things I plan to do is wrap the inside of the toolbox with Dynamat. Will cut down the rattles and resonance created by the air pressure. I can shake the lid easily right now and it's adjusted real tight already. Won't make a huge difference but should add some lost thump.
Sub
Reactions: JTW and Jshell3
rocmar
rocmar
4,741
5,778
4 CORNERS
Your post...proved my point
Thanks...
196,414
Thanks...
No, not really. A 3" set up the way it is in a soundbar will not produce much bass. Your statement was a 3" does not and will not produce bass.
Back in the '70's, Bose introduced the 901 series. Those are what put Bose on the map. It had like eight 3" and two horn tweeters in each cabinet. They were known for being unblowable. My brother had a pair and those speakers would straight up punish you, hit so hard they'd make you blink.
Like most electronics, hi fidelity is a science. All depends on the equipment and how it's configured. A 3" is capable of producing bass though.
Now those are what I need in the Bazooka party bar!
Reactions: trigger
rocmar
rocmar
4,741
5,778
4 CORNERS
Wat ever
...your other post read
3"bass worked for 15 min...
Then never worked....again
rocmar
rocmar
4,741
5,778
4 CORNERS
Trig...
I'm talking sound bars..
I've heard 4 different
Models....3 different makes
They all sound ...like an
AM radio...
Do you have a sound bar?
My soundstream amp/bass
Of 150 watt....
Does & did...wat I posted
rocmar
rocmar
4,741
5,778
4 CORNERS
Does not...will not
PRODUCE ENOUGH BASS
TO MY LIKING...
SOUNDBAR....
& just to add....
Your quick on me...sayin
Pics or it never
....happened. .
But never said that
To Montecresto. ...or LandPioneer
...when they said there windsheild
....had not ONE scratch.
Which we all no is BS
@JTW im thinking about getting one of these. If you hook up one of those tube bass speakers, will the sound bar have enough power to support it or would you need a separate amp?
I honestly can't answer that.. the way mine is sealed it would not be an easy thing to do. But truthfully.. it's not too bad as far as bass goes. It's much better than I thought it would be.
