P1000 Spare Tire Thoughts?
Jbird
Jbird
392
475
Mena, AR
What are the pros and cons of having the same tire all around. My P1K-5 Deluxe came with narrower tires on the front. What about using the wide rear tires all the way around? If you are sticking with narrow on front and wide on rear, which size do you pick for your spare?
67,223
After you get into the 30+ size range you don't have many options.
Pro: rotation.
Pro: easy spare choice.
Con: wider front = less controle when turning.
Con: wider front = possibility of clearance issues.
I'm still in decision my self as a set of wheels/tires are in my future.
Jbird
Jbird
392
475
Mena, AR
Pro: rotation.
I'm pretty happy with the stock Bighorn 2.0's that came on this thing so will probably stick with that. I would assume if I put the rear ones on the front that they would not rub. Maybe someone has tried this.
Reactions: JTW
Pro: rotation.
Any reasoning against going with the narrower front all the way around?
A
arizonasteeler
23
40
mesa arizona
i just purchased a new itp steel rim 12 inch by 7, 136 4+3 off set and a used tire for about a hundred bucks. just for precaution for an elk hunt i have coming up.pretty cheap alternative until i put new 14 inch rims and tires next year. rim itself was under 60 at a local shop i know offset not great but it will get me through the day if needed.
Reactions: JTW
Check Amazon..
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
My new daughter knocked one of my Evos off the rim Tuesday. It was the driver side rear. I use one of the front stock wheels as a spare. It worked just fine getting us back to the trailer. If you do the same, be sure and run it in turf mode so you have an open differential. Otherwise youll have wear and tear on your pinion trying to run 2 different size wheels on same axle.
sugarray
sugarray
Is this a game show?
661
1,257
WV
Good info guys, these have been my concerns.
@JACKAL will you post your thoughts about your 6+1 offset wheels and same size tires all around?
Reactions: Bubbadoyle
I hope @JACKAL doesn't mind me stepping here. I would think about the narrow track width. Jackal had to do it so it fits in the toy hauler. If that's not your reason, you may want to consider 5-2 or 4-3. It will sling more mud but there are options for fender flares.
Sorry I forgot, did you lift your vehicle? Jackal has his lifted and more narrow and it can be more tipsy when loaded heavy.
61129ebeeb1ad151f35c0ab6fd122716
Signature:
QUOTE by Eltobgi, Honda...Strong enough for the Farm!...Dependable enough for everything else!
Reactions: JTW
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
I still say it was your fault. You were sitting on that side.;)
Reactions: JTW and joeymt33
chillout
22
12
Tx
Where did you get the "new daughter''? One of mine is a pain, and did you get any trade in?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Got her from Children's Services. We have 3 siblings along with her still lol. It's a challenge sometimes but very rewarding. We like to think we're making at least a little positive effect on a sad situation.
208,729
Signature:
Don't need to go through all that stuff, just get training wheels! HA!
208,729
Signature:
Is that a 500? Don't think so, was there alcohol involved?
There was no alcohol involved. But don't worry, we were only going to hit the easy trails!
" jak9922" lmfao grilling hotdogs on a stick over an open popo hahahahaha
