sorry for the confusion it is a 2015, I thought seat belt safety switch but can not find any switch located near the seat belts. it is for sure some sort of safety not letting me rev it up. brake lights work as normal and gear indicator which is only reverse and neutral. its weird even in neutral when you go to rev it up it won't. it cuts spark to keep the unit from reving it up. I can see 12v from the ecm at the coil and when I probe the ground side there is no ground. but the ground wire is good from the coil to the ecm. not sure if that means anything. appreciate you guys chiming in to help. any help is appreciated.
The ground side of the coil is the signal side. With a test light from batt positive to coil ground, you should see flashing when cranking/running...but that's all redundant. If the machine is running at all, that's all ok, so i would concentrate elsewhere.
Here's my thinking...and maybe some other 700 owners can chime in...BUT, I'm pretty sure the start in gear feature will only work if you aren't giving it throttle (Someone want to test this for me?). Or maybe that's just true in reverse. I don't have one anymore, or I'd give it a try...
That's the reason I said it sounded like something with the SIG.
For that reason, I'd try and correct the lack of proper gear indication, and I bet the other will cure itself.
I'm pretty sure 2015's don't have the seatbelt disable.
