T
Have a Kraftwerks turbo Talon which I pulled the motor and replaces, pistons, crank, rods, fuel system and everything in between, but I found myself running the stock spark plugs. In my opinion they should be the best spark plugs on the planter for $30 each, but someone mentioned I would be running a lower heat range plug. I didnt some googleing and have only found information about people using the stock plugs. Obvioudly my tuner couldnt tell me an exact part number for the same plug with a different heat range but I am assuming SILMAR7A9S would be the SILMAR8A9S with a lower heat range? I am starting to get some rough starts and weird idling on cold starts so my first suspect is the plugs. Wanted to go for the low hanging fruit before I begin chasing a vaccumm leak.
Has anyone used a lower heat range plug in their turbo talon? If so would you mind sharing a part number?
