No. Not really. These machines are designed to handle full speed when in 4 wheel drive.Is there a limit on what speed or gear you should be when your in 4 wheel drive?
Take it out...& run it
Bro...tough machine
likes to be Rode
I run 25inch maxxis bighorn tire. Could not be happier.Hello all, 2016 Honda pioneer 500. Can i put tire size to 25's, will it hurt my machine. Thanks
26x9x12's on all four corners.. I will probably go with 27's next timeHello all, 2016 Honda pioneer 500. Can i put tire size to 25's, will it hurt my machine. Thanks
Thanks, i'll stick with the 25's. im a short guy,with 27's id need a step ladder to mount. :}26x9x12's on all four corners.. I will probably go with 27's next time
Honestly it's not much taller.. but that little bit of ground clearance makes a HUGE difference!Thanks, i'll stick with the 25's. im a short guy,with 27's id need a step ladder to mount. :}
For 27 u will need frame mode.26x9x12's on all four corners.. I will probably go with 27's next time
I didn't think they'd hit until 28'sFor 27 u will need frame mode.
Sent from my XT1585 using Tapatalk
I think I could get by with it running 27x9x12.. but it will be a while before that happensPlease consult with member "Stacy", he has BH originals 27'x 12x12 and had to cut frame to accommodate them. I recently spoke to him and once I wear my BH 2.0 , then I will jump into 27" 12" wide all around and will do frame mod
