Spot the difference
HondaTech
20210902 161458
Sheetmetalfab
Sheetmetalfab
2,218
13,996
Alaska
We cracked our racecar cases in this spot awhile back.
We were told they were revising this area because of this specific issue. This is the resulting revision they alluded to.
On the LV non SE.
Must be a later build date.
Reactions: ChadD and Blownzuki
SLOWPOKE693
SLOWPOKE693
1,861
7,350
Somewhere in Texas
Mtex Racing Products came out with a case brace a few weeks ago to stop the case cracking problem. Elliott Cook broke 3 sets of engine cases on his Talon for various reasons and hasn't had a single issue since installing this brace. I ordered one up a few days ago. I'll do a writeup on it once I get the part.
20210823 104030
208,728
Does it still let the motor move in the frame mounts?
Reactions: ChadD
SLOWPOKE693
SLOWPOKE693
1,861
7,350
Somewhere in Texas
Yes, It has nothing to do with the motor mounts. The MTEX brace supports the center of the steel bar that connects the engine to the mounts on the frame keeping the bar fom flexing and breaking the lugs that are cast into the cases off.
This picture shows the result of what happens when that bar flexes. The brace connects directly to the mount bar in between those lugs and will not let the bar flex in that area preventing a costly headache.
HondaTech
Odd, we cracked ours on the opposite side, where they updated the mount i showed. I hadn't seen issues with the drivers side.
The 2020 models added a spacer under thr bolt that mounts the enigne to the metal bar, not sure what the reasoning is. We added these to our car.
SLOWPOKE693
SLOWPOKE693
1,861
7,350
Somewhere in Texas
Odd, I haven't heard of problems with the one on the other side. Maybe the Talons with the new style engine mounts shown in your picture are the ones breaking the ears off because it's the new weak link?
Got any pictures and/or part numbers for the spacers?
I picked up a set of Delrin bushings to replace the stock rubber ones in the motor mounts. Figured throwing that brace on there while I had it all apart wouldn't hurt any. If I can get the spacers you are talking about in a reasonable time frame I'll install those also.
Reactions: ChadD
HondaTech
50335-HL7-A20 Spacer (2)
95701-10055-08 Bolt (2) Should be around 23mm longer
After doing some digging, it appears they put this on thr 4 seaters first in 2020, then all models in 2021.
Where'd you find the bushings for the engine mounts?
Reactions: SLOWPOKE693
