I did the mod earlier on the shifter levers [didn't have my camera that day] Anyway this is what I did this morning to stop the cold air leakage around the E-Brake lever. The shifter levers are similar except there done under neath the hood and I used a motorcycle inner tube stretched over the metal and then just zip tied the tube shut at the end were the cable passes thru.
First I cut out a piece of cardboard template then cut out a piece of Alum. to fit into the opening around the E-brake lever. Earlier in the summer I had picked up a shift boot from the wreckers off of a 90s Dodge 4x4 truck. I cut the boot to fit inside my Alum frame and pulled it out around the sides so that when I screwed the plate down there was rubber comming up around the sides of the Alum frame sort of creating a gasket .Now the E-Brake lever is sealed off just like the shifter's ,
