P500 Storage box options
154,379
Was considering the Tractor Supply box in your photo. I get on some rough roads and was concerned about how much the box would raise the center of gravity. I believe it weighs 40 lbs. have you noticed any increased tendency to tip over? Thanks....
That dude's probably never coming back but it's the same box I have. @100Acre has one on his too. It's a big box and does raise the COG, there's pics of the Giant Gnome on his side all over the forum. :D
But it holds a lot of sh**! Always dry and locked up too.
Reactions: Eltobgi
103,203
After flip flopping the 8 or so times, my locking mechanisms no longer work. When traveling on the trailer I use 2 locks and a chain to keep the lid secure. When trail riding I switch it to some bungee cords. Was thinking about replacing it but.....
Reactions: trigger
Bruce4795
112
248
Arizona
This Tractor Supply box weighs 27 lbs, has a gasketed lid, and is lockable. It is very light for its size. It is the 48 inch model that measures 46.5 inches long. Installed using 3/4 inch rigid conduit clamps and 1/4 inch by 1 inch long carriage bolts. I marked the hole locations underneath using a cut down q-tip dipped in black paint held by pliers. I used 6 clamps total (Lowe’s electrical section)...2 on each end and 1 on each side toward the cab side...be sure you can get to them to tighten them. The clamps hold it very secure. I wasn’t able to get any washers on the nuts, but they are so tight I don’t think they will work loose. I used a small mirror to make sure the black paint spot was there before pulling the box and drilling the holes. See photos for more information.
1F3A8D36 6AB1 44EA 924C C5BEBE01D708 AFAD1F4C 576D 4112 AF02 6EBCE98112DE ADDE10AF F480 4343 B98F A44DDFD42928 B698A90A 18C7 40E3 ACA3 EA7728BE54CF 935887E2 151D 4FDB A2C9 E407B7FF4BC0 D1FFD205 3B89 4C2A B2C8 B0D2130BB288 6D8550E5 2548 4DAF 9545 5C1945B32081
Mudder
Mudder
NTC Ambassador of Walls
11,273
83,552
Looks good @Bruce4795 , I thought about conduit clamps after I had used some u bolts lying around. I did buy some for future use and glad you provided feedback that they hold well.
Reactions: Fordman
Bruce4795
112
248
Arizona
I just installed some mud buster rear fender extensions and had to remount the box after they were installed. I was only able to install 4 clamps, 2 on each side, instead of The original 6 locations due to the wider fenders. 4 seem to be holding the box just fine.
Bruce4795
112
248
Arizona
a few photos of my P5 with the long travel kit and Mudbusters in case anybody is interested in this combination.
E0956BC9 680E 41AA B5FC 56AB341E3D16
31CF6E84 C912 4B3B 876B 9754D362D6C4
FFFA0E1A 9841 4C5B AAB9 C33BA8364A71
Fordman
Fordman
160
272
Fayette Al
That’s true ! How are you Trigger ?
Reactions: trigger
Fordman
Fordman
160
272
Fayette Al
Great my Friend , I doing pretty good too , Happy Father’s Day to you as well
Reactions: trigger and Mudder
Kracker
Kracker
127
227
Louisiana
If anyone was waiting for “cheaper” storage and rack options found two items on sale this week be in tomorrow get it installed will post pics.. HF atv hitch rack for $39 using 20% off coupon, and Walmart has the 48” tool box for sale around $140 ish so both for less than $200..
4FB49297 A94C 4BD5 A52A A2EFC0193993
4AAA5E4D A312 4DDB BF1F 3E5B5BAFBF4E
Reactions: Mudder
K
Kilroy
92
284
53
Lowes use to sell 48" side mount tool boxes with the Kobalt name on them for $78. Probably the same manufacturer that makes the Better Built and other boxes. I looked online the other day and Lowes no longer sells the Kobalt brand boxes, just the Craftsman brand and they are $200 now.
