P500 Storage box options
GaryG
GaryG
58
40
KY
What is the best storage box options for the rear rack of the P500.
I have a small Plano box zip tied on there now, but i could use a little more room.
Thanks,
Gary
Reactions: Isaiah
Hard to beat a husky tool box and a strong made basket setup!
C9A96300 C97F 4E88 BB3D 197826AA9C5B 1FD52EF8 FF83 4CC9 BF47 FB82CD256872 810FCF06 7FD2 4F80 A33E DAFE97056F0A B67F1BAF 75C0 4048 ACB2 1121F57AF401
GaryG
GaryG
58
40
KY
I have been looking at these. Has anyone tried these boxes out?
Also only one looked like it had a shock to keep the lid from closing up on you. Do they make something aftermarket to keep it from closing your head or fingers up in the box?
https://www.amazon.com/dp/B003VZGWMG/_encoding=UTF8?tag=sxsweb24-20
71qmDe92BnvL SL1500
https://www.amazon.com/dp/B01BRDW0VA/_encoding=UTF8?tag=sxsweb24-20
619Ao3YivNL SL1200
https://www.amazon.com/dp/B018F547UK/_encoding=UTF8?tag=sxsweb24-20
615wPa3MRaL SL1000
https://www.amazon.com/dp/B001VLWH3A/_encoding=UTF8?tag=sxsweb24-20
71TFKB3zv L SL1500
182,153
This should give you some ideas. Lots of different set ups here.
P500 - P500 Member Showcase
GaryG
GaryG
58
40
KY
I found these boxes at Walmart. What is the best way to connect them to the rack?
D3d889967acd6565d645b0f198f6141d81e5e9c5c3c74f8ea5e38307865a6c91C2e0524992f5263ada0fc9e0541a2f8e
U bolts or I drilled down through the racks and ran straight bolts.. be sure to add washers between the box and rack to minimize rubbing on the rack.
Redrocket
Redrocket
56
58
Lake City FL
I bought one of the poly boxes from tractor supply, mounted inside of metal golf cart bed.works great.
R-Lamm
R-Lamm
315
242
South Carolina
Well that was obvious wasn't it.... I may be a bit blind.
With so many options out there...it never hurts to ask! Folks on here are always happy to help in any way they can! This basket is a very well built basket and fits perfectly with the tool box style shown!
Reactions: monaco and JTW
Mdds
Mdds
17
Halifax, Nova Scotia
7B9B8020 C216 4091 A4B5 60A247E58C09
Thanks,
Gary
Hi Gary. I had one custom built and its awesome. Tool box goes on one side, gas jug on the other side, and my Tote is in the middle. Still have room around the sides with a drop down tailgate at the rear. With this design i can still carry lots mire gear or totes as im still below the top of my storage box.
Bruce4795
112
248
Arizona
Tractor Supply box and Honda Strong Built front rack mounted behind the box
Was considering the Tractor Supply box in your photo. I get on some rough roads and was concerned about how much the box would raise the center of gravity. I believe it weighs 40 lbs. have you noticed any increased tendency to tip over? Thanks....
Reactions: trigger
