P700 Strong made lift kit
swsebek
swsebek
2,854
5,829
pa
Installed this lift last night.Pretty easy and about 3 hours later I'm very happy with it.gave me 3 more on rear and 2 more on front.I will test it out more today or tomorrow.If you get this lift hold the pics up to a light and look through the paper they are mirrored images for some reason.the fronts were very easy and the rears are a little more difficult and require more unbolting.fronts you only have to unbolt the bottom shock bolt, on the rear you have to unhook stabilizer bar and top a-arm bolt.
IMG 1610 IMG 1611 IMG 1612 IMG 1613 IMG 1614 IMG 1617 IMG 1622
Guito
Guito
91
142
Seminary MS
View attachment 40950 View attachment 40952 View attachment 40953 View attachment 40954 View attachment 40955 View attachment 40956 View attachment 40957
Have you put shocks on yet? Everything work well with lift?
swsebek
swsebek
2,854
5,829
pa
still in transit it says...I wont be able to install till Friday night....The lift made the stock shocks feel better too me....but I will have to test them on trails.My tires don't rub anymore on fender flares,and my azz aint sagging is a plus:DI like the stance better too.
swsebek
swsebek
2,854
5,829
pa
Ok I haven't yet received my Fox shocks yet but I have had some time and gave this lift a chance.The ride is great and has made the stock shocks feel like the way I hoped the Foxs would.By bringing the bottom mount in further it makes the shock work easier to hold the weight better by havening less leverage out. But remember I still have my stabilizer bar connected. The ride is fantastic now and the stance is taller.I ride the same area a lot and have had this machine for 3 solid years.makes 28 inch tires work easy with no chance of rubbing the mudd busters bolts. I wished I had got this lift the first year,cause I probably would have been happy with stock shocks and a 1 inch spacer.also I lost 2 inches of width.I will post after fox shocks are on.next Mod will be power steering
Reactions: lizenbe
Max718
Max718
246
366
Mississippi
Looks good. I installed the strong made 2 1/2 inch lift kit on my 2017 pioneer 700-4 took a couple hours very happy with it
Reactions: swsebek
BeachBum
15
12
DFW Texas
I am looking into the strongmade lift kit for my 2017 700-4. For those of you that have been running it for a while, anything negative to say about it? Thx.
swsebek
swsebek
2,854
5,829
pa
Nothing negative to say ..easy upgrade and height increase.
Reactions: Deluxe700
208,029
That looks pretty simple, and sweet! With your Fox's you will be able to set spring sag and voila! That should let you use the entire shock stroke.
Reactions: swsebek
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,601
Ridgeway, SC
Has anyone used the Strong Made 2” lift with the Super ATV arched arms for a P1K-5
Flgator_80
Flgator_80
274
422
Lexington, Tn
Does it work? We trying to add a arms and the lift acts like it don't want to work
REBrider12
5
10
North Carolina
Old thread but anyone looking into the strong made lift for the p700 I strongly recommend. Lifts machine about 1.25”-1.50” and keep cv angles in a good position and not in a bind. Maintained the factory ride quality and helps with the front shocks that like to bottom out.
This is my pioneer with the strong made lift and 28s.
B455B8A6 C245 4B47 AAAA C87ED19D9170
