P1000 stuck in 1 gear
slowdryrider
slowdryrider
572
778
Canada
do you know if your getting power to the shift motor ???. Also there is that hexagonal shaft right next to the shift motor that you can turn manually and shift into neutral.
Hillbillytnt
Hillbillytnt
550
2,023
Ky
I am having the same issue with mine. and yes the 1 is flashing. do you know what that means and/or how to fix it.
How is it blinking. Long short. Long = 10 short =1. For example one long three short is a code 13. That may give you a number code That will help narrow it down more info will help these guys diagnose it.
115,793
Welcome from Michigan!
Pics Or It Didn't Happen!
Of the machine...
As stated earlier is it flashing a code?
  • Love
Reactions: ChadD
slowdryrider
slowdryrider
572
778
Canada
You need to give more info so people can better help you. And yes a code would be a big help.
Reactions: ChadD
