P500 Sun F tires?
43,589
Just bought a set of the Sun F .I've only had them for a week so far they great had to lower the pressure to 6 lb.It goes so much better and smoothed the ride up a lot.
What's sizes you go with? Any pics?
Reactions: rtn001
hondabob64
hondabob64
215
795
Louisiana
604C3335 8DF2 41BF BCA9 A6DD7DB8D61C
196,414
I’m ordering these tomorrow.I need to fit the tight side rails on my trailer so I think I’ll mount them on the stock wheels.
It's going to look BA but I would highly recommend spreading it out a little or it's going to be a pucker fest. You sprung for the tires, $100 more for some spacers would do them and the machine justice, whole different animal. ;)
hondabob64
hondabob64
215
795
Louisiana
It will not fit my trailer if any wider. That’s why I didn’t spring for new wheels. I couldn’t find the look I wanted in the proper offset. But it’s used strictly for deer hunting so I’m good. And no lift. I’m transferring from my wheelchair to the seat & need it as low as possible.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
In answer to your original question - I just put new 26x9-12 SunF Power II tires at all four corners on my Pioneer 500 about two weeks ago and so far I love them. I've already put some tough miles on them and I'm impressed.
Reactions: rtn001
Backwoods
Backwoods
37,766
376,242
Douglasville ga
Are they a very heavy tire? Did you ever measure height? I always look at tire weight when I shop . It's a big factor in my decision making. I looked at them before but never could find any specs. I put some Artrax on a quad before they where great tires but a 25x10x12 was 36 lbs. Super heavy.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
I’m with you - power to weight is important. I don’t know the weight, but I bought the Power II because it’s lighter than the Power I, mimicking the Bighorn and Bighorn 2.0. I measured today, at 8psi the top of the tire is at 25.5”, which means if not mounted on the machine it would be right at 26”, and 26”+ with more psi. Yes the new wheels/tires feel heavier than the stockers when I handle them, but I’m not sure by how much.
bigr244
bigr244
136
194
US
Ordered mine yesterday. I'll have an exact weight for you next week.
Sent from my SM-G935V using Tapatalk
