Multi Sunk my poineer
Blindman74
5
Florida
Hi I was pulling a small trailer with my 2015 pioneer 500, i was doing yard work. I made a mistake cutting the corner of my pond and sunk the machine. It cut out almost instantly. I shut key off and pulled the side by side out. Checked oil absolutely no water in the oil, I drained water out of exhaust and air cleaner. I dried everything out. When I turn the key the starter clicks and tries to turn but no go. Did it lock up? It ran very briefly in water and no water in oil. Is there a safety sensor?
Reactions: TDos and Shannon840
HUCK
HUCK
1,047
2,315
ARIZONA
THEN TURN IT OVER WITH THE PLUG OUT . IT HAS WATER IN THE CYLINDER . CRANK TILL IT QUITS SQUIRTING THEN SPRAY WD4O OR THE LIKES IN THE CYLINDER . PUT THE PLUG IN AND FIRE HER UP . SHE'LL BE FINE .
HUCK
HUCK
1,047
2,315
ARIZONA
it could have hydro locked but hopefully not
Reactions: William
Blindman74
5
Florida
Thank you
11,348
84,458
Also check gas and diff fluids. Dude called MuddMan has a lot of videos posted on you-tube and one is where he totally sank his P500. Enjoy, and there are comments in his post from others that sunk theirs. Also a post on multi site about breather hose and gas issues when sunk and check out Drowned Out posts under P500.
Reactions: ehart814
swsebek
swsebek
2,854
5,829
pa
swsebek
swsebek
2,854
5,829
pa
I WAS GOING TO ASK, BUT THE FLIM ANSWERS THE QUESTION. HA!
Yep, that was soooo funny when he says looks deep:D then you hear him under water and the beer can floating :eek: then man this is cold.I think I ride with this guys distant relative.We call him WaterBug
Reactions: Smitty335 and TDos
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
That would be a good video on one of those epic failure shows and now the handle of Mudder is making sense.
207,989
Also check gas and diff fluids. Muddman on you-tube also totally sank his P500 and there are comments from others that sunk theirs. Also a post on multi site about breather hose and gas issues when sunk and check out Drowned Out posts under P500.
I would have never posted that here, now everybody knows your IQ on beer! HA! I have never done anything like that. HA!
Reactions: swsebek
207,989
I have never done anything like that. Stupid poop. HA!
rocmar
rocmar
4,741
5,773
4 CORNERS
Dude..I laughed. .till I
cryed...hope your p5
is ok..
