P1000 Super atv windshield rattle..
K
Keller6
5
5
Pa
My super atv windshield rattles against the clamps when its closed... seems like it's not closing tight enough... anyone else have this issue?
P1000_DLux
P1000_DLux
Its Only an Opinion Relax
Belfair, WA
So I have just mounted mine and it does rattle all be it quietly on larger bumps. However, I am going to put a second long strip of weather strip along the main windshield seal. then I'm going to add a single small tab on the upper brackets
Sxs windshield
P1000_DLux
P1000_DLux
Belfair, WA
20200329 000013
Quiet as can be now. All I hear is my engine. Soooo Nice.
Got the rubber weather striping at the local hardware store. I used clamps on the sides for a bit to make sure the double back stick would stay put. Worked great.
Russ989
Russ989
22,642
147,257
Sometimes you have to adjust the latch.
Pmed489
Pmed489
119
137
I mounted a 1 inch angle to the bottom to stiffen the bottom section. I has worked very well. Mounts to both side brackets and to bottom of latch on bottom
