P1000 Surging Idle 2018 LE - SOLVED.
nbomar
nbomar
4,416
17,855
Springdale, AR
This post is for my mom. Her 2018 LE 1000-5 has started surging from 1000-2500 rpm at idle and while in gear. Her friend is helping her work on it and they replace the IACV thinking that was what was wrong with it. While in there they found the intake hose was busted and replaced that as well. Also found the oil return to the top of the motor was busted and replaced that. It's still surging. Any ideas on where to look for a fix would be great. Thanks,
Nick
212,772
Nick
The leads went bad on the injectors and IACV, no issues since.
Reactions: Plumber32
nbomar
nbomar
4,416
17,855
Springdale, AR
Ya common for the wire to break on the connector head. Non visible break.
I'll send you a connector. how fast you want it?
Is your address still the same?
It needs to go to my mom. 7522 Benjestown Rd. Millington TN 38053. You can just address it to me. I don't think it needs to be rush shipped.
Reactions: NewHere2
63,026
Nick
Holy s*** a ghost!
21,764
93,366
Make sure the IACV is seated correctly. I believe @HondaTech has ran into that issue in the past.
Quick check for injector wires is wiggle them, it should die when connection breaks.
