P700 Suspension compression
d_b
d_b
302
240
This idea comes from plumber32, I'm sure others have done it however he brought it up. Anyhow how much you getting ? Before and after measurements would be great for lots of us. Also maybe some suggestions on placement and type of straps.
Thanks all,
swsebek
swsebek
2,854
5,835
pa
yes rear is easy, but what do u do to front?
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
@Plumber32 any chance on getting some pictures so we can see the technique?
69,244
I haven't had to do the front, but rear is real easy. I just loop a rachet strap from the frame to the a arm on each side and cinch it up. Pulls it down nice and easy. I don't have any pictures.
69,244
This idea comes from plumber32, I'm sure others have done it however he brought it up. Anyhow how much you getting ? Before and after measurements would be great for lots of us. Also maybe some suggestions on placement and type of straps.just the regular rachet straps you use to tie it down with. I'll try to get a picture of where to do it tonight, you can pull all the travel out of the suspension if you wanted to, but it easily makes it 2 in shorter with little effort
Thanks all,
