P700 Sway bar removal?
livefromthetree
livefromthetree
464
1,299
Mount Vernon Indiana
I sprayed the tubes up and down with fluid film, like I do with about every hole I find, or make. That is a great thought though, I'm putting them back in as I type... Well actually taking a drink of beer as I type, in between bolts. At this rate I should finish the beer as I tighten the last one😎🍺
Swing down thru south Indiana and unhook mine and I'll buy you a beer too ;)
livefromthetree
livefromthetree
464
1,299
That's just putting the bolts back in the holes. It took a 6pack to get it off🤣 If I were a little closer I definitely would!
Ok I am out. I drink a 6pk way too fast and work too slowly. Prolly take me a solid case and then there's no way it would be right!
I'll look at it and go from there. Probably have my catch all mechanic at the store pull it for me in a few minutes. Heck I paid him $40 to put led lights on my trailer and that was way too much so he owes me :p
livefromthetree
livefromthetree
464
1,299
I looked at mine last eve and thought I can do this. So without taking the tires off I broke out a wrench and ratchet and started on one of the links. It broke free, but the damned nut wasn't moving. Then I tried to retighten it and it wouldn't tighten back up. Looking at both sides, it looks like the nut never moved that maybe it's just spinning on the bolt head end although I can't feel it spinning.
See I told yall this was a bad idea 😅 . This can't look any simpler, but yep I gave up. I am gonna run it to the shop and let my do all mechanic snatch it off unless someone can tell me what I should try next to get the bolt out of the link.
43,568
If your talking about the link out at the end, those spin like a tie rod end. You have to hold the center with a hex bit, or the flats on the back side (next to the rubber boot) with a wrench (preferred). They are locking nuts, so they will have some resistance all the way off.
livefromthetree
livefromthetree
464
1,299
Aha 🤣
livefromthetree
livefromthetree
464
1,299
Getcha some of this. Took me about an hour maybe an hour a half. Once I figured out it would be easier to get to the nuts if I raised the bed it went much smoother 🧐.
Thx for the help boys and girls. Much appreciated.
11 days before I load this thing on a trailer and drag it all across the midwest for 8 weeks.
It's almost time!
IMG 20201007 38804
IMG 20201007 38670
livefromthetree
livefromthetree
464
1,299
Bring the links with you, just in case.
Woah slow down. Just in case of what? Other than being hairy in a higher speed turn or curve, what would cause me to want to put them back on?
DBD
DBD
67
141
Pennsylvania
It's almost time!
View attachment 228795View attachment 228796
What tires are those? I like the looks of that tread.
livefromthetree
livefromthetree
464
1,299
I was torn between those and the Blackwater Evolutions. I got evolutions 28×10-12. I love them but now seeing the tread depth on those... How's the mud/snow with those? What size? Are those commander shocks?
Mine are 27" on factory tires and shocks. Havent had them in snow and dont do any heavy mud. There's a few guys on here that have posted about plowing snow without issue though.
Hickstrong
Hickstrong
45
37
Pa
How does it ride with the sway bar off over rocks? I about rolled mine on its side over the past weekend. Spacer lift and rocky trail dont mix. just put on 2 front commander shocks and I'm gonna remove the sway bar tonight when I switch the 2 back shocks. Also is the body roll now noticeable on flat ground around turns?
