P1000m5 Tailgate Quick Removal Mod
Robobrainiac
Robobrainiac
2,550
8,957
I am not sure if anyone else has done this. I wanted to be able to remove my tailgate quickly and easily. This is how I made that possible.
This was performed on a 2020 Honda Pioneer 1000-5 Deluxe. It should apply to all 1000-5 and 1000-6 models. I assume it should work on the 700-4 since it uses the same tailgate.
You can do this to either side. You only have to choose one. I did my driver side. If done slowly and patiently you should not have any marring or disfiguring of the external panels. The goal is to heat the plastic enough to make it pliable. You are reforming the plastic. Take your time and there should not be any holes when you are done. Heat the area evenly and hold it in position with pry tools and let cool. Then repeat. Until there is enough room to remove the tailgate pin. Make sure you do this in a well ventilated area. Hot plastic is not good for you.
The tools needed:
Heat Gun
5MM hex
10mm ratchet
Multiple Prying Tools
20230628 150046
Remove the plastic end cap. It can melt.
Polish 20230628 231328233
Heat this area evenly with the heat gun. Take your time and be patient. The plastic is high heat resistant and seems to take a long time to make pliable.
Polish 20230628 231933233
Pry the area back. It will take time, different angles, and different size pry bars until the area is pushed back enough to give room to remove the tailgate pin.
20230628 114256
Remove the 10mm bolt.
Polish 20230628 232101963
You should have enough room to slide the tailgate pin out.
20230628 140635
Remove the two upper tailgate cable bolts.
20230628 141206
Lift up slightly on the side with the removed pin. Angle it towards yourself and then slide it off of the opposite pin.
20230628 141216
Your tailgate now installs and removes with 3 bolts.
20230628 141246
I used some anti-sieze on both sides of the pins to help in future removals. It took me about one hour to complete this project.
Robobrainiac
Robobrainiac
2,550
8,957
My ultimate reason for doing this mod was to be able to utilize a bed extender and swap out tailgates when needed. I am happy to report it worked great for me. I found a used complete tailgate on ebay for $78 and installed the Rough Country Bed Extender onto that tailgate. I can now swap between the two tailgates in 5 minutes.
20230630 121747
