Ride Royal Blue MAP INFO - POI's, Unmarked trails, Shortcuts. Pioneer Takeover!
66,871
Some Pioneer Takeover, Ride Royal Blue Trail Map Info and POI's
Full map with several POI's
POI's
  • Waterfall near trail 3.
  • Waterfall off trail 8 (must walk 300ft)
  • Top of world above trail 30.
  • Cafe on 21.
  • Boulders on 31.
  • Waterfall top of 37.
  • Elk Viewing tower (must hike to it)
Twra sundquist unit trail map jpg
61e208b4cc0127e09f43fb57968f2467
FRIDAY NIGHT PATH TO TOP OF WORLD!
Trail Path: From RRB Trail 27, Left to19, R30, (Top of World) Stop and chill a bit, Continue on 30, R28, R29, R13, R19, L27 back to RRB.
99b192afadcbf339d1512413ed5bc3df
Some COOL Cave & Boulders!
Boulders you drive in between. And a Cave.
Trail is not too difficult. Several spots a beginner may need help spotting.
Mud holes if you want to get stuck.
Trail 20 is a good trail. I recommend this path if you are lookign for good ride.
Starting at lower 19 (not shown). (will retake pic to show)
20 Up, 31 down, 21 up, 20 down.
3e507657475565d2204afec84f02a542
Trail 26 By-Pass and unmarked roads.
Trail 2 is a very nice ride. But to the unknown, you have to go up trail 26. The first 1/2 of 26 is experienced riders only. It is a large mountain climb with several challenging switchbacks and hill climbs.
BUT... There is a gravel road bypass.
BYPASS - Once at end of #2 & bottom #26 you will see a white church. Continue on out and to the left. You will see a gravel road. That will take you to the 1/2 way point on 26 and will bypass the difficult sections. Rest of 26 is easy.
23 & 13 are NOT a dead ends, It is just a road not part of the system. You can see the added roads.
B09911866d99c49a4076a445e7383246
VINEYARD1909
VINEYARD1909
60
115
Chatsworth Ga
Thanks these will be helpful and we are getting up there early Friday morning and coming back Saturday night so should get to see a good bit.
Reactions: sharp
66,871
I cleaned up this thread for 2018. Info remains the same.
MOST IMPORTANT INFO
  • The lower 1/2 of trail 26 is not passable. There is a dirt road bypass that goes from trail 2 at the church 1/2 way up to 26. Take this to pass all the hard spots in 26. *see picture above.
  • Off of 26, Trail 23 DOES connect to 19 via a gravel road.
  • In this same area, 13 DOES connect to 19 via a gravel road.
  • You CAN legally ride from the campground to the trail head at 13 for a easier start/finish.
  • You CAN legally ride from the campground to trail 10 on the road too.
69,057
MOST IMPORTANT INFO
26 not passable? That's almost impossible . Why is it not passable ?
Reactions: sharp and joeymt33
272,200
That was last year 2017, had 8" rain 5 days before takeover and machines with 30"+ tires had fitted it so bad even they were flipping over and around.
In good condition on Trail 26 a P500 can barely pull 2nd gear, add mud it's 1st gear only and pray it doesn't spin out on the 43% incline switchback.
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
We did try it.
There is a long hill rigs slide down but couldnt make it up.
The brave might can side stance around it but not many succeed!
Pull the cable out!
Reactions: sharp
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
Did you ride with Royal Blue Rangers Group ?
We did try it.
Reactions: sharp and Smitty335
