P1000 Taking CFab lift out
Mark in Northern Iowa
464
2,075
Floyd County, Iowa
kramnella.wixsite.com
Probably, because that is what I run with stock suspension on my 2018 3 seater. 👍
BF Goodrich KM3 28x10x14 and ITP delta steel rims.
I've been told my ITP Delta wheel are 5/2 offset rims, I do not know for sure.
I do run a 1-1/2" spacer on the rear.
All 4 tires and rims are the same.
Tire Front 2
Tire Rear 1
I have read that some owners rub at full compression and turning. I have never been, or plan to be, in that situation, so no problem for me.
Have a good day
105,327
So I’m wondering. I’m thinking of taking my cfab lift off and going back stock. So I have 30 x10x 14 carnivores on now. First of all what do y’all think and can I put 28’s on when I go back to stock suspension. I have a 2018 3 seater.
Is that Lift kit a bracket or full suspension?
105,327
It’s an an arm lift. It’s unique it’s built in with the forward and rear offset an arms. Built in Mississippi. It did what I needed it to. But now it’s more of a hunting and work rig. Hopefully it will smooth my ride out also.
See ya’ll… proof the bracket lift is a rougher ride cuz they change the suspension geometry not to mention everything else in the drive system is off. I already knew this cuz I had one years ago for a while. Most folks go back to normal or a true suspension lift
bigshoe
bigshoe
421
1,425
28s carnivores on stock rims will rub for the first 500 miles on sharp turns and full compression. with 5+2 rims won't rub at all. im on 29-9-14 megabites with 5+2 rims only rub at full compression turning.
20230128 154517
Jas sxs
Jas sxs
137
525
rankin county ms
i am running 30 -10 - 14 carnivores on my 2021 1000-5 with no lift i have high lifer a arms + 2 on front , back is stock with no problems
Mopower58
Mopower58
CST is the Best!
70,139
644,215
Crystal Springs,Ms.
I've got BH II 28x9x14 on front and 28x11x14 on rear on 5+2 wheels and 1 inch spacers on rear. No rubbing at all.
IMG 0343
