Talon Talon A-arm
Had a little rollover.
Not suppose to back up on those steep hills....🤷‍♂️
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
Since we’re showing wrecked Talons
0D2E4176 5794 449D B822 6BEF69B7FE6D
0DCAE436 614F 44E9 A507 D00357E47B75
75AE7633 0138 4D95 9A85 38EB4A265E55
PaulF
PaulF
1,462
4,816
I feel really bad, I derailed this thread and it had gone WAY off topic.
OP is looking for an upper control arm, let's get back on topic and see if we can help him out!
jamesh
jamesh
253
350
DFW
Where in Arkansas? I've been to Hot Springs ORV and rocked that place with a P500. Can't wait to get back that direction with my X4. I got the long wheel base just for what you were doing.
Maybe just get some aftermarket arched A-arms?
I'm so new to SxSs that my Talon has zero miles. That went from good to bad in a blink. I'd have thought after watching the first one motor right up that hill, that I'd be safe to follow. :eek:
And you would be...😉
Reactions: CID
OP happened in Missouri. HS ORV is ok if small. WPG is close to there and a better ride IMO.
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
I have to know the story behind this!
It was towards the end of a great ride. We were less than 5 minutes from the trail head. I went way too fast off an off camber jump at the top of a small rise at around 50 (it’s hard to tell with the crappy display. I drive it like a dirt bike by sound and feel through the gears. You’re going too slow if you have time to watch a speedo) and it kicked me sideways in the air. It was a tight trail with no room for forgiveness. I landed crossed up and punched it into a tree at full throttle. It was a strange angle as the tree went between the bumper and fender. It wasted both A arms, the tie rod, shock, knuckle, hub, axel, front diff and bent the frame along with the bumpers and metal skid plate. The broken ball joint machined out the inside of the rim getting it out. It still ran and would turn the drivers side front tire even with the axel out of the diff. The I4WD light came on when the fluid drained out but It didn’t keep the machine from moving as others have been concerned about. We winched and drove it out with a buddy holding the tire up. The Simpson D3 harnesses saved my butt for sure. I still can’t believe the plastics weren’t destroyed as hard as it hit. The tree was about 18” across. She’s all back together now with a new frame and some new upgrades. I recommend insurance. They cut me a check for 14K to cover the damage on a $600 - 12 month premium and $500 deductible. I’m guessing it’s going up when it’s time to renew.my policy.. These are the first pics all greased up when I got it back
949552BA 7EB8 4226 AD2C 9BF4C7B004B3
B18DCA94 56BF 4DBB 881B 9496EAC25E2F
