HondaTech
Doing my first Talon clutch replacement (2nd time for shop) wanted to share some thoughts.
At first it appears to be a somewhat intimidating job, but its actually not as bad as it appears. The whole thing can be done in frame by removing the rear differential. On an "R" you'll also have to remove the left side 4+ link to get the oil tank out. If you do take this arm off you can do a full clean like on a Pioneer by removing the rear engine spacer to clean everything out. Other than these few extra steps the rest is just like a Pioneer.
Also if you have any bad axles lying around, remove the outer joint and save the half of the part that inserts into the hub. If you ever have the machine apart and need to leave the axles out you can use this stub to reattach the wheels and roll the unit around instead of it sitting in 1 place. The same part works for all 4 hubs.
