Talon X 4 Oil Change
Does anyone know of a complete kit for changing the oil in both engine and transmission that includes the 7 quarts of oil, both engine and transmission filters and the crush washers and any o-rings??
Reactions: Isaiah
Reactions: Isaiah
Ok I found the kit you referenced elsewhere, it’s all good. Thank you!
WTXoffroader
WTXoffroader
36
102
Kermit, TX
Gaskets on drain plugs and orings on filter covers.
Sorry, it didn't show me that it was no longer available.
Here's another one that does include the orings.
Sent from my SM-T837V using Tapatalk
That’s the ticket right there, thank you....👌
Reactions: WTXoffroader
DorkMissile
25
37
Twin Cities, MN
FWIW - I own a 2016 Honda AfricaTwin DCT (which is basically the same engine and similar transmission to the Talon) and have done probably a dozen oil changes & DCT filter changes reusing the crush washers and O-Rings and have had zero issues as far as leeks go
Reactions: Montecresto and CID
hondabob
1,281
5,089
Prescott Valley, AZ
If you don't over tighten the drain bolts it may not be necessary to replace the drain bolt washers. I used the original o-rings and washers on my talon at 15,000 miles and Pioneer 1000 with 19,000 miles. Its important to oil the o-rings and carefully rotate the oil filter covers as you fully install them.
