P700 Throttle positioning senor
A
AltonRd
Tx
Is there a way to check sensor on 2015 700 ?
Mine cuts out if you give it gas.
hondabob
1,318
5,245
Prescott Valley, AZ
Check your spark plug cap. Several have come apart. When you give it throttle load the firing voltage goes way up and can arc to the cylinder head. The sensor can be checked but its a PITA without the shop computer.
A
AltonRd
Tx
Actually that's not correct.
This guy has an excellent explanation of the tps.
I now understand how to troubleshoot it better .
Hope this helps some of you .
