P1000 Tie Rod HELP.
THEDUKE_SXS
THEDUKE_SXS
15
29
FL
Threads from the Inner tie rod broke off Inside the Steering Arm. This is why its taking so long. Three different easy outs, torches, welders. Still in there. @ODAMO
Screenshot 25
WagginTail
WagginTail
1,651
6,059
SC
I watched a YouTube video one time but haven't tried this. The guy took a copper pipe that would fit down in that hole snug. Cut it off flush. Then you can mig weld inside that copper pipe on the broken bolt until the weld is up to the top. Then you can weld a nut on it. I think the guy actually used an old screwdriver and then just kept working that broken bolt till it came out. The copper pipe keeps weld from getting on the inside threads. I'll try to find the video.
THEDUKE_SXS
THEDUKE_SXS
15
29
FL
I tried every trick in the book. The last thing I did was a easy out in the broken bolt. It is not a reverse thread, the easy out bite hard and would not remove the bolt. I welded a old socket to the easy out and used an impact with torches. The easy-out twisted in place and never turned the broken bolt.
I think my only option at this point is drill and tap or replacement. I have a replacement internal steering rod. Just not sure how to remove it yet.
211,882
Have you tried heating the female fitting portion of the fitting? Not so hot that it heats the male threads.
ODAMO
ODAMO
1,390
3,658
Ohio
You probably have to drill all the way thru and close to tap drill dia. To weaken the broken stud. If the gods start to smile down upon you, you may luck out and not have to retap. Either way, when you finally get it out you will get another hole punched in your man card.
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
What kind of easy out have you tried?
May I suggest this? Get the one with the drill guides. If you have an easy out broken in the rack, you are pretty much screwed unless you have some expensive drill bits for the hardened steel.
1681320258170
Not exactly cheap though.
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
Are you not sure how to remove the rack from the machine?
Or how to disassembly the rack?
THEDUKE_SXS
THEDUKE_SXS
15
29
FL
Disassemble the rack itself to replace the internal steering rod that the inner tie rods screw into. I have a replacement one of them, just haven't had a chance to figure out how to tear down the rack to access it.
Similar threads
