P700m4 Tie straps location
80sforlife
Best location to use tie down straps on P4 to transport on trailer. Everytime I secure tie down straps on recommended location on rear bar the suspension causes straps to come unattached from trailer. Any ideas?
I had the same problem. I purchased this kit and four extra axle straps. I have no more problems with it now. It also allows me to tie to the wheels if I like. If I tie to the bumpers, it still stays connected due to the clips on the ends of the straps.
http://www.summitracing.com/parts/mtd-513216
Reactions: Hondasxs
The link wouldn't work for me. Here's a pic from the summit website.
8d6c3f0b9075ddbc15f260bda66fe473
I had that issue either the rear coming loose occasionally, noticed it was only when I strapped the front down first.
I have a 12' trailer so the straps pull against each other pretty well.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
I have not seen this problem yet. Knock on wood! I haul one some real curvy and bumpy roads. Remember when securing a load such as a vehicle use parking brake, leave in gear and diff lock, and Never put straps or chain over brake lines or wires. When you find safe locations tighten all 4 corners out at 45deg angle so that when you rock the vehicle the trailer moves with it and without slack in the straps. I will start down the road and bounce, swing and brake check the load. Then pull over and retighten my straps.
Reactions: joeymt33
Yup in 4lock with E Brake on.
The rear bounces enough it will free itself. I have 2" 4500lb ratchet straps one front one rear. I run the rear around the hitch ball and tighten it down till its tight then run the front behind the bumper and tighten it down till she's squatting. If I do the front first no matter how tight I get it the rear comes loose occasionally but if I do the rear first haven't had an issue.
My last trip to Top Trails down there by you Mr Creek I had my rear strap come loose 2 times. I think I strapped the front first and had the same problem. When I purchased those Mac's strap, I figured a couple hundred bucks was cheap insurance for a rig that has $15k or so in it. The real scary thought is hurting a person with a load tie down issue.
Joe
Reactions: ohanacreek
Joe
Agreed thats why I went with the 4500lb rated straps. The Pioneer is a dynamic load it is always shifting because of the suspension, and dynamic loads are dangerous loads.
http://www.newsday.com/news/new-yor...unit-onto-midtown-manhattan-street-1.10492036
Dynamic loads also wear on your straps so they need to be replaced periodically.
We need to get together and ride, sorry you couldn't make it this past time.
Marc Cummings
Marc Cummings
10
I was told by someone to always leave it in neutral so it will roll out of the way as opposed to flipping down the road with it in gear if it does come off the trailer.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
@Marc Cummings I hear you but at that point?!? If the SXS has already left the trailer it is a very dangerous situation either way Wheels locked or not. I think that the propose of the 4 wheel lock and parking brake is that if you are heading down the road and you notice a strap unsecure it will afford you some traction between the trailer and the SXS to allow you to get the vehicle to a safe stop. I hope that made sense.
I am pretty sure that I could hang my trailer upside down and the SXS would stay on the trailer! I use the C130 cargo loading formulas that not only allow for "tying the SXS down" but also allows for the G forces that would occur in a crash! We should be not just securing the SXS for the trip but we should be securing it for in the case of we get in a wreck that the SXS stays on the trailer and the trailer stays with the Truck. It is very important to secure in all directions!!! Forward, back, side, and vertical. If anyone would like I would be happy to post this stuff from a manual.
Marc Cummings
Marc Cummings
10
I hear you, I don't do a very good job tying my ride down to the trailer. can you post some good suggestions on points to hit?
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
I hope you didn't think that was aimed at you? If so i am sorry It's just that I have had Safty drilled into me!! And I know that I can get carried away up on my soap box preaching about it lol. But yes i will pull out my info this weekend and get someing posted here for everyone.
Reactions: Marc Cummings
Marc Cummings
Marc Cummings
10
Not at all. I kept cutting straps and need some pointers. Any suggestions are greatly appreciated.
Psylas
Psylas
77
49
Anchorage, Alaska
I use to have that problem with the commander. Bought a trailer with rails. Keeps it nice and corralled incase the straps came off.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
I am just going to post this info and let y'all read it. If anyone has a hard time reading it, I’ll try to explain it further just ask. I know the 1st time I read it I had to get someone to translate it to good Ol' Boy for me to understand.
  • load master help.pdf
Thanks for that info @bobbyhill. It was a good read this morning. Maybe I should have read it before hauling the pioneer 3 hours round trip yesterday.
Here are some pics of the straps and and locations I used to secure the pioneer.
812eada9101c15ed4a9dd0ca3a268251
0f79852ef459b828438a8d99cddb3011
E8682c595cbc51b412caf63d86ee53e1
Oh yeah, and I leave it in 4-lock with parking break set.
Joe
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
Great pics!! I like those straps!!
RunningBear
RunningBear
Alabama
I have towed heavy equipment, farm equipment, ATVs, etc. for years and am very particular about how I tie them down. The Pioneer is actually one of the easiest things I have to tie down because it has four handy hook points on each corner built right in!
The attached photos show where I attach the straps front and rear (four total when towing). The straps in the photos are NOT what I use to actually tie it down on the trailer. I use much heavier ratchet straps. I just grabbed them to demonstrate in the shop. These tie-down points are structurally very strong. I'm also not shy about getting the straps good and tight so that the Pioneer doesn't move!
Strap Front
Strap Front Closeup
Strap Rear
Strap Rear Closeup
allgm1
allgm1
1,049
1,484
New Hampshire
I read a post once (don't remember where) where somebody used these straps that basically strap the tire down. the straps get bolted to the trailer and ratchet around the tire, they looked like a good option also. I'll dig around and see if I can find it.
I have towed similar to that. I have put the 24" straps through the wheels before. The vehicle does sway more with out the suspension compressed but I'm sure it's safe.
