P700m4 Tie straps location
Springer
Springer
312
234
The
I have towed heavy equipment, farm equipment, ATVs, etc. for years and am very particular about how I tie them down. The Pioneer is actually one of the easiest things I have to tie down because it has four handy hook points on each corner built right in!
The attached photos show where I attach the straps front and rear (four total when towing). The straps in the photos are NOT what I use to actually tie it down on the trailer. I use much heavier ratchet straps. I just grabbed them to demonstrate in the shop. These tie-down points are structurally very strong. I'm also not shy about getting the straps good and tight so that the Pioneer doesn't move!
View attachment 5127 View attachment 5128 View attachment 5129 View attachment 5130
These are the tie down locations I use. Because I have Fox shocks installed I also set the clickers to full compression to keep the rig from bouncing up and down, and use the parking brake. I had gotten into the habit of putting it in neutral from my atv days. I heard if you leave it in gear you could ruin the gears if it rocked back and forth too much.
When I am done, it don't move!
What Honda has to say
575fe004f879e262a11c1ce1af2c8b1c
What I used to do...it let it shift side to side some as the tie downs are only pulling end to end against each other.
5e715b9a3d5c40c85fdd20bb1f498091
I bought a 4 pack of HD tie downs after reading the loadmasters PDF.
Tramguage1
Tramguage1
Texan
7,500
30,748
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
In Texas law is 4 points of contact, that means 4 separate tie down points.
I had an old timer tell me that my rock krawling vehicle was tied down wrong.he told me that if you tie down to a part of the vehicle that is above the suspension that as the vehicle bounces,it could cause the hooks to detach. So i use 2 axle straps and 2 ratchet straps on each axle. He told me the tires do not flex as much as the suspension.
20141206 075909
Reactions: Hondasxs
