Multi Tilt Ratings on all new models?
266,470
This is the reason and explanation. You can thank the Yamaha Rhino for this standard.
Federal Register :: Safety Standard for Recreational Off-Highway Vehicles (ROVs)
Original
41,933
IMO the Rhino just bought the segment into the mainstream, and as such, suffers the blame. Had it not been popular, the next machine up probably would have gotten it. Certainly the 50" machines would have raised eyebrows....
Wish there was a table published of actual results for machines. That's what I'm interested in seeing.
No they were just plain tippy, designed more like an ATV than a cart.
They did have less historic data to go on but a bad design is still a bad design.
41,933
Tippier than a 500?
Havent spent a ton of time in a Rhino, but I can't see it being worse.
...but then again, that's why I'm curious as to the ratings. Maybe it just seems that way.
Backwoods
Backwoods
32,525
333,667
Douglasville ga
I would like to know how many degrees a p5 could go but I took my tags off and did not read them
Rhinos were awesome for their time... and are still good. It was completely sue happy folks going after number one. I mean it’s not the machines fault when we put ourselves in precarious places. The fix for the rhino was to remove rear sway bars and add spacers.
Amazing what that does for a 1000....
Reactions: Mopower58 and JTW
41,933
Okay, so what's more stable: a two-seat Wolverine or a 700-2?
Well, if you said the Wolverine, you are wrong! At least according to the CPSC...
20180516 125156 20180516 125845
OK...so they are equal. Still, a lot of people comment that the 700 feels top-heavy. Same thing for the 1000 but it's not true, relatively speaking...
20180516 125449
The big loser in this show room? The wolverine x4 barely makes the 33 degree minimum...
20180516 125352
The machine is was most interested in seeing was the 500 Pioneer. Unfortunately, they didn't have a 2018 on the floor. Might head to another dealer shortly, and I have more for comparison later.
41,933
Wow I would’ve guessed there was a much bigger difference between 700-1000
Yeah...would have bet the 2 seat wolvy smoked the 700. Some of these are very surprising, but I'll have to post later when I get better signal.
Reactions: JTW
41,933
I’m calling bulls***...
You still would have flipped it regardless.:D
Actually, when you consider that the 1000 has 27 inch tires, more ground clearance, etc that probably offsets the extra width, it seems like it makes sense.
Reactions: ohanacreek
41,933
I have a tilt meter in mine and 35* isn’t that extreme. I’d like to see and know how they perform their test.
It's in one of the links above.
Reactions: JTW
I’ll be the first to say they will dump over and with weight added it highlights it... I would say these numbers were pretty accurate when I had 1000 lbs in the bed on the overland and couldn’t keep the wheels on the ground. But normal riding without the weight... no way!
41,933
I believe they add 450 lbs for the test.
