Multi Tilt Ratings on all new models?
Here I fixed it for @JTW
3e15c37647fc9a8736b0d77b44e6728a
210,960
I think that decimal point needs to move to the right 1 place.
Dumb question, did this come from the government? That would explain the results, print it out on toilet paper and use it! HA!
Reactions: JTW
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
I saw my guage hit 35 several times at RRB and I didn't feel like I was going over. I don't think 36 would but I'm not sure if I'd make it past 40....
Reactions: DG Rider
I really think it can be pushed to 45 as max given what you’re hauling.
Reactions: DG Rider
ToddACimer
ToddACimer
Pioneer 1005-2
3,804
16,188
Oshkosh, Wi
This is a neat comparison number but it's only going to reflect static performance of the vehicle with 2 occupants. Since most of us have added weight at or below the vehicle vertical CG (bumpers, heavier tires and wheels, skid plate,etc), we should be able to do slightly better than these numbers. Another important factor is rarely will you traverse a side hill perpendicular to the slope so you're pronprob going to be climbing up and across or down and across the slope, both of which will allow a steeper incline to be traversed without rolling
Reactions: JTW and Smitty335
lee
lee
Village Idiot
2,440
13,815
Springfield Ohio
Adding the factory roof will un-do any imagined benifit of all the stuff listed. (There is a warning label or somthing that we all ignore about this)
The CG just gets worse.
However, what you add to a Pioneer is what you probably would have added to any thing else listed.
So as a starting point you can understand the relative capability - my p500 will tip before @ohanacreek but he will stop for a snack while I flip mine back over.
See, it works. It's all good.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,084
Bella Vista, AR
I was suprised the difference I could tell when I removed my factory roof and put on the spidershade.
Now that you mention it, it’s time for a snack now.
I think the way it’s done is one of the rare times(maybe the only time) a government agency got something right. They probably had a lot of help and hand holding by the private sector.
I can’t believe I’m about to say this concerning something the govt is involved in. It actually makes sense and is usable information.
Reactions: JTW
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Except for the fact that everything is rated almost the same.
So its more red tape that proves nothing .
I wonder how much money was spent for this little project.
Reactions: JTW
