Tips for replacing fuel pump. 2017 Dodge Ram 1500.
66,868
Anyone have any tips or tricks for replacing fuel pump on a 2017 Dodge Ram 1500.
Fuel level sensor has become faulty.
Thanks.
Neohio
Neohio
Beast of the East
14,586
73,808
Painesville Ohio
You really only have 2 options, drop the tank or remove the bed.
You aren't really in the salt belt, so either should be really easy to do with standard cordless tools.
43,055
@dg_rider might have some insight
Don't think I've ever done one on that body style...but yeah, drop the tank or raise the bed.
Shouldn't be a problem since it's just the sender bad, but always check the connector for signs of heat when the pump goes. Often melts the connector causing a poor connection on the new unit.
Robobrainiac
Robobrainiac
2,551
8,962
Thanks.
Put a bigger pump on it and turn it up for extra coal :p
As others have stated, pretty standard process, drop tank or lift bed.
Reactions: ChadD and Smitty335
208,726
Thanks.
It's easier when the fuel tank is low to drop the fuel tank, if it still runs drive it until you burn some fuel out of it.
Reactions: ChadD
Robobrainiac
Robobrainiac
2,551
8,962
This may be helpful
Screenshot 2022 08 29 16 48 56 23
