drfubar
TheDonFather
I've had a tire that loses a couple pounds of air in a weeks time. It didn't bother me that bad because I'd check my tires weekly anyway and add air if I needed. Then I had a second tire slowly losing pressure so I decided to try one of the tire sealants on the market. I didn't want to use "Slime" because of the mess involved when changing tires. Did some research and settled on "Tireject". The fluid is the consistency and color of milk and cleans up with water so it should cause a mess when changing tires. Ok, I settled on the gallon jug priced at $129.99 but found a 20% discount code offered by Tireject bringing the price down to $104.00 and free shipping.
How it worked.... I followed the directions and added the required amount to each tire, (16oz) for the 30x10x14's I have on the Honda. They have an app that you can download and use to figure the amount for your tires. Anyway I aired the tires back up to my prefered poundge and ran the Honda off and on for a couple of days. Here it is 2 weeks later and I haven't lost any air in my tires. The stuff works great. I know there are several companies offering tire sealant and probably some may be a little cheaper. I don't have a problem with the tires on my trailer but I think I'm going to add some them just in case. Website says it will also fix punctures and dry rot. Here is the website, you can read for yourself. TireJect - Easily Repair Flat Tires - Highest Rated Tire Sealant
