Tire additive works
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
I've had a tire that loses a couple pounds of air in a weeks time. It didn't bother me that bad because I'd check my tires weekly anyway and add air if I needed. Then I had a second tire slowly losing pressure so I decided to try one of the tire sealants on the market. I didn't want to use "Slime" because of the mess involved when changing tires. Did some research and settled on "Tireject". The fluid is the consistency and color of milk and cleans up with water so it should cause a mess when changing tires. Ok, I settled on the gallon jug priced at $129.99 but found a 20% discount code offered by Tireject bringing the price down to $104.00 and free shipping.
How it worked.... I followed the directions and added the required amount to each tire, (16oz) for the 30x10x14's I have on the Honda. They have an app that you can download and use to figure the amount for your tires. Anyway I aired the tires back up to my prefered poundge and ran the Honda off and on for a couple of days. Here it is 2 weeks later and I haven't lost any air in my tires. The stuff works great. I know there are several companies offering tire sealant and probably some may be a little cheaper. I don't have a problem with the tires on my trailer but I think I'm going to add some them just in case. Website says it will also fix punctures and dry rot. Here is the website, you can read for yourself. TireJect - Easily Repair Flat Tires - Highest Rated Tire Sealant
20190311 121252
Thanks for the review.
Mopower58
Mopower58
CST is the Best!
71,285
652,696
Crystal Springs,Ms.
Great review. I used slime in all 4 tires (27 inch mud-lites) of my Rhino. Never ever had a slow leak or flat and ran them for 7 years. When I replaced the tires 7 years later the slime was still in there in a liquid state and all I had to do was wipe the wheel off as most of the slime was in the tires.
Marcel
Canada
I’ve been putting slime in all my tires in all my machines for the last 10 years. We used to have some sh!t heads that would dump roofing nails on the trails and I’d get several over the years. With slime preloaded in my tires I have all the confidence that I’ll pull them out on the trail and not worry about leaks. Even with several holes in them, I’ll go months without loosing air.
