P1000 Tire and Wheel Question
JB1000
64
26
Pennsylvania
I have a 2016 Pioneer 1000-5. I still have the original 12 inch stock rims and tires that came with it. I'm going to buy new 14 inch rims and either 27 or 28 inch tires. My question is are those sizes all compatible without needing spacers and having a steering problem? My second question; is the bolt pattern 4/137? Thanks John
Reactions: Isaiah
Sjc3081
Sjc3081
263
442
Wappinger NY
If you want to keep your factory width proper offset 6+1 front and 4+3 rear.
Russ989
Russ989
22,565
146,497
JB1000
64
26
Pennsylvania
[What can I run without adding spacers. I just want to put new tires and wheels on without adding spacers. Thanks
Sjc3081
Sjc3081
263
442
Wappinger NY
Spacers are to even you wide front to your narrow rear because 5+2 offset sucks proper offset is 6*1 front and 4+3 rear and no matter what wheels you use any tire that actually is more than 27.5 to 27.75” will rub
TripleB
TripleB
11,694
99,254
Caryville, Tennessee
You dont have to have the spacer in the rear. I ran mine that way for months. You can't tell the difference unless you break out the measuring tape. That being said I added a 1 inch in the front and a 2 inch in the rear about 3 weeks ago. Just to give it a little more stability since I'm a little taller now. After that I had no choice but to add mudbusters. I just hope it doesn't cause other issues now. In 3800 miles the only thing I've had to do is change tires and brakes.
Reactions: JenElio and JB1000
JB1000
64
26
Pennsylvania
What do you guys think would be better with the 14 inch rims 27 or 28 inch tires. Im thinking about putting the terrabites on. 8 ply I believe.
Reactions: JenElio
JenElio
JenElio
64,241
602,732
Loxahatchee, florida
28" gives you a bit more side wall and a bit more ground clearance. 👍
Reactions: JB1000
JB1000
64
26
Pennsylvania
So I can put 14 inch rims on and 28 inch tires without spacers correct? Sorry for all the questions just don't want to screw up when I order these tires. I just want to be able to put them on without changing anything. Thanks John
JenElio
JenElio
64,241
602,732
Technically yes, most ppl run a 5+2 offset rim for rotation purposes. But by doing that the front of machine will be a little wider then the rear (thats where the spacer comes in play) but u CAN run them with out spacers.
JB1000
64
26
Pennsylvania
Because my machine is stock and doesn't have a lift or anything do you think I should upgrade to the 14 inch rims from the 12 inch stock? My question is should I get the same size tire for all 4 corners? I believe they are like 28-10-14. Sorry for all the questions.
JenElio
JenElio
64,241
602,732
U can, same of 4 corners means u can rotate. Better. The DLX comes with 14" rims so theres no problem there. And 28" tires are the tallest u can put on a stock machine. 👍 my 2 cents, I would buy a set of spacers and make it even just for stability. These machines are top heavy as it is. The wider the stance the better.
JenElio
JenElio
64,241
602,732
And yes 28-10-14 with a. 14" rim and 5+2 offset works
