P700 Tire wear
DBD
DBD
67
141
Pennsylvania
They should only come in 10 wide on 28s . You can but you might want to put a 1inch spacer on all 4 to widen for stability.
I'm looking at 5-2 offset wheels now, that should suffice for the spacers you mentioned if I'm correct, as well as give me the ability to rotate wheels and tires and have a fifth for a permanent spare. If I like the set up the stock wheels and Sedona mud rebels with 400 miles on them will be back ups.
Reactions: Backwoods
Backwoods
Backwoods
37,776
376,293
Douglasville ga
That's what I have 5+2 wheels . I'm not much of a spacer person.
Reactions: DBD
DBD
DBD
67
141
Pennsylvania
They do have the 28's in 8 and 10 wide on RMATV/MC
DBD
DBD
67
141
Pennsylvania
28 10 12 all around. Amazing set up!
0724200043 0723201920 HDR 0723201939 0723202033
DBD
DBD
67
141
Pennsylvania
Looks good, did you notice much loss with them and do they rub ?
Very slight power loss with 8lb pressure all around. No rubbing at all, although haven't hit anything hard enough in a sharp turn to see if they may rub then. I'm a pretty cautious driver built I'd rides like a Cadillac up and down rocky rutted trails here in the Appalachians of Pennsylvania.
