P700 Tire/wheel upgrade concerns
Hickstrong
Hickstrong
45
37
Pa
if you don't have power steering, then don't go wider in the front, 2" spacers made it more stable after can am shocks in the front and a 2" spacer in the rear for now. i would like to go 27" but it barely fits inside my trailer.
Dockman
Dockman
168
344
I am worried about my trailer.
Hickstrong
Hickstrong
45
37
Pa
I meant the height of the buggy not the width...lol the roof barely fits under the slide down bed in my restored 5th wheel
Dockman
Dockman
168
344
I have 27" tires in 5+2 wheels. Can I add 1.5" spacers on front and 2" on back or is that asking for problems?
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
I run 27s on factory wheels with no offset. Zero power loss that I've noticed, no stability issues and no rubbing. Picked up a couple inches in height as well.
20200822 222853
20200822 223229
20201030 131140
Dockman
Dockman
168
344
I have 27" tires on 12" wheels now. I would like to add spacers but not sure it's a good idea with wheels already have 5+2 offset
7d6af072709b24b1691431e223e2911d
Hickstrong
Hickstrong
45
37
Pa
If you tow anything of any considerable weight then you will bog down towing hills with 27s, If you go wider in the front especially with no power steering you will loose some maneuverability while cornering at faster speeds, there is a reason they are skinny in the front. Even though its more of a slower utility sxs some of us like to step on the gas now and then.
Reactions: Mudwing
Backwoods
Backwoods
35,803
362,219
Douglasville ga
I wouldnt IMO . I run the same setup as you and mine is up hill , down hill in the mountains and stability is fine.
Reactions: Mudwing
