P500 Tired of auto downshift..
906UP
906UP
13,006
121,243
da Yoop
2015 & 2017 had a different number of teeth on the final drive, the only way you'll get around this is with a Speedo DRD, check the link in my signature below.
nctrailboss
nctrailboss
440
1,454
north carolina
To get all of the little kinks out,I used the 15-16 module,15-16 speedo pod,and as 906 stated,a speedo DRD.He is right,there is a difference in the number of teeth that the speed sensor reads from on the 15-16 models vs 17-on.It was all plug and play for me.I much prefer the "no auto down shift".Glad I did it.
Cooint
6
12
illinois
Thank you guys for the quick response. Can one of you send me the link to the DRD you used and Speedo POD Part number from 15-16 (assume this a Honda part number?)
nctrailboss
nctrailboss
440
1,454
north carolina
It takes the H-3 SpeedoDrd. If I remember right,you set it up at about negative 14%.
SpeedoDRD
Reactions: 906UP
Cooint
6
12
illinois
Just a follow up on converting my 2017 to pure manual shift. Purchased Honda ECM (Part# 38770-HL5-A04 - $136 and a SpeedoDRD (Model# SDRD-H3) - $70 and installed the DRD with a -14% setting as recommended by you guys and everything works perfect. No need to purchase a new dash display. It shows "L" rather then "D" when put into 1st gear just like my brother's 2015. Shifting feels quicker and more positive. Glad I did it.
Reactions: 70Bones
11,313
84,049
Glad it worked out. Good details, Without auto downshift, will the engine bog down if you let it, or will the clutch just disengage. Thanks. ( I have a 2017 also).
nctrailboss
nctrailboss
440
1,454
north carolina
Just like all Hondas with this clutch set up,if you don't downshift before the clutch starts slipping ,you will hurt it.It will not stall,but reaches a point where it will not move the machine.
nctrailboss
nctrailboss
440
1,454
north carolina
I agree,much mo better.
156,270
Took off with mine from a dead stop in 5th. Pulled it onto the trailer that way too with a little momentum.
nctrailboss
nctrailboss
440
1,454
north carolina
Don't do it often.
20150504 205446
