P500 Tires/Rims same for Foreman 500?
O
OutdoorEd
Have a chance to buy never used takeoffs (rims and tires) from a 2016 Foreman 500. The only difference I can see is that the stock tires on my P500 are 24's and the foremans are 25's.
Main concern is the rim bolt pattern and potential offset causing an issue with the pioneer.
Can someone confirm that these will go on the pioneer 500 seamlessly, or will there be an issue?
500oneer
500oneer
15,000 mile club
428
1,083
Central PA
I have a 2015 foreman and those tires are junk. Just buy 26 inch big horns for your stock wheels. Foremans have a straight axel and is a different offset than the rubicon which is the same as the p500.
Reactions: OutdoorEd
15HP500
15HP500
Alberta Canada
I had a 2011 Rancher 420 that had my 26 zillas on it. when i got the p500 swapped them over before i sold it. fit on perfectly.
