tires rubbing
Charlie0909
19
picked up new 700-4 today and the dealer had 27-10-14 motoclaws on all four. i liked the way it looked so kept them on but the front rub on hard turn under a load. any suggestions other than calling the dealer.
K
kyhunter
127
Some guys are running 28" Bighorns on 14" wheels and no problem.
How much PSI is in the Tires? Also what kind of wheels are they & the offset of the wheels?
Charlie0909
19
they are on m20 kore wheels but dont know the offset.
K
kyhunter
127
Ok M20 Kore are 14x7 come in +0mm & -52mm.
bigc
bigc
432
127
are the front tires made wide or is the height making it rub ?
L
LouisianaMarine
I bet you its those wheels man. They are something like 3.5+3.5. You would think is they stick out further they would rub less but thats not true at all, it forces the outer rear edge of the tire to rub the inner fender when fully turned the direction of that particular tire providing that you also have a large enough tire.
Charlie0909
19
Could I heat the plastic where its rubbing and try to reform it?
Charlie0909
19
Louisianamarine, that is exactly what they are doing.
L
LouisianaMarine
As far as how to fix it, I'm sorry but I don't think I can help. I would probably figure out how to rig it to make it work on my machine, but that's bad advice. The good news is that the problem has been identified so you can move forward with suggestions on what to do. The real answer is the one you don't want to hear I'm afraid and it rhymes with "mange the schmeels".
67,230
I have tried this on an Atv before. Wished I had not. It did not turn out well. But plastic has changed a lot since then.
LouisianaMarine said the best answer.
T
tbaker
365
637
NW. Georgia
I just put a set of 27 inch GBC dirt tamer tires on the factory rims and it looks bad ass and it does not rub. I have the 2 seat pioneer in green.
Charlie0909
19
I think its more the width. I have 10inch wide on the front.
K
kyhunter
127
I'd call the dealer before I done any kind of mods. It's not your fault that it rubs.
Charlie0909
19
Honda of Russellville took care of the problem. Replaced the tires and wheels with the ones of my choice.
67,230
Awesome news.
Been following them online. They seem like a good group.
What did you go with. 7 inch wheels?
