P1000 tires would not roll when needed them the most
322,690
@wyodlr is correct. You didn't have enough power for the solenoids to work correctly I believe you're good. Check ground on battery as welldual battery would help in the future
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
In the mean time charge your battery back up. Just running the machine won't bring it back to 100%
Reactions: JTW and jocojonson
Nic
Nic
45
59
Oregon
Why wouldn't it? If that's the case the battery would never be a 100% because anytime you start it, it drains a little juice. Has a charging system and regulater.
