Took pionner in deep water won't crank
jae12
6
I took my pionner through a deep water hole it went all the way through when I came out it cut off it cranked up one time but when I gave it gas it cut off any help would be appreciated I do have it snorkeled properly and have done It before so I don't know what happened
67,231
Not good.
I will assume you have done the general.
- cleared the hydro lock.
- cleaned the air box.
- checked the oil and checked for water and replaced if found.
The last 4 guys who sunk theirs found there solution with the fuel. Seemed water entered easy. One guy found a inch of water.
You will need to siphon the gas out and fill it up with 2 to 3 gallons of high test and run it before the leftover water settles.
He did that and it cranked right up
viewtopic.php?t=1431
