Scoop
Found a couple of threads via 'SEARCH', but nothing definitive and nothing recent.
Recommendations for good 3/8" and 1/2" torque wrenches?
I have a 3/8" Tekton that's good for 10-80 ft-lb. I've been using it mostly for the bead lock bolts lately. What I don't like about is it seems like you can torque a bolt to, say, 23#, then put the wrench right back on it and it will tighten even further. Seems like the tolerances are somewhat wide. Or maybe my using one only 5 times a year = I don't really understand that's how they all work.
I don't really have a need for a 1/2 drive torque wrench, other than lug nuts and a few other bolts that are right around the 80 ft-lb range, but I know when you use any torque wrench at the lower or upper end, it can be unpredictable.
I don't really want to drop $400+ on Snap-on or other high end stuff, as I don't use it all THAT much.
For the most part, I don't use torque wrenches. I've been wrenching so long, I know when things are "right". But for something like bead lock wheels that have elevendy hundred bolts and having them all reasonably close to one another can mean the difference between leaking or not leaking, I'm willing to put a torque wrench on there.
Dial torque wrenches more accurate than click-style wrenches? I've heard that a few times as well.
Appreciate any input.
