P500 Towing your pioneer 500
lwhite571
lwhite571
431
3,575
Central, IN
20170429 155925 HDR
Reactions: alloutdoors
Little_g
Little_g
404
660
Parker, AZ
Ok I have a dumb question. I have a 63x120 Aluma trailer that I use to haul mine. Do you guys use the tow/haul mode when you guys pull yours? Not very familiar with all the towing techniques and tricks. Thanks for any input.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
What kind of truck do you own?
HUCK
HUCK
1,047
2,319
ARIZONA
That's what it's for so you may as well use it . It will cut your mileage a little and your p5 and trailer are so light you really don't need to .
Little_g
Little_g
404
660
Parker, AZ
Ram 1500 5.7. I guess I haven’t because I didn’t think it was that much weight back there, but wasn’t quite sure. Kinda new to the towing thing. I know my parents always use to pulling a horse trailer but not sure on this one.
alloutdoors
alloutdoors
1,022
2,184
US
Put it in drive and go.... You are likely pulling 2000-2500 lbs total, trailer is likely 1000 lbs and the unit is 1000 and if you round it up to 2500 lbs total with gear that is absolutely nothing to worry about in terms of pulling it.
Reactions: Little_g
Little_g
Little_g
404
660
Parker, AZ
Thanks for the info everyone! Like I said new to this so wasn’t sure. Great group of knowledgeable people.
alloutdoors
alloutdoors
1,022
2,184
US
Once you start getting 3500-5000 lbs you will likely want to switch it and when getting into the 5000 lb range you then want to invest in some kind of brakes on the trailer, so you can whoa that load.......
Little_g
Little_g
404
660
Parker, AZ
I’m only planning on pulling the p5. Maybe a 1000-3 within the next year or so.
alloutdoors
alloutdoors
1,022
2,184
US
I’m only planning on pulling the p5. Maybe a 100-3 within the next year or so.
Good to go.... I think the P1000 3 is something like 600-700 lbs more.
alloutdoors
alloutdoors
1,022
2,184
US
I found my used P500 after extensively looking and everyone one of the used ones I was looking at are now sold, so the market is strong for them...
196,345
Keeps it from kicking in and out of OD, won't shift gears until higher rpm either. It keeps morons from burning up their transmission. It will kill your gas mileage though.
