Trail Armor Skids + ITP Terra Hook 32x10-15
eagleXP
eagleXP
19
37
Longview
I got new skids and tires installed. I was expecting a-arm guards in the kit, nope. I just looked at the pictures, if you read the description, kit does not include them. But at that price I thought it would.
I mounted the tires on the factory wheels, i was not looking to buy new wheels until I FUBR one. But...you can tell the front is wider now. I marked the ground with sidewalk chalk. Not the most accurate, but I got 61 3/4” in the front and 59 3/4” rear. So two inches wider in the front.
Should I get spacers in the back?
Super pumped about the skids, I destroyed the factory stuff in the 1st 100 miles.
The picture below is the front wheel well, it’s got a pretty big over hang that needs trimmed up. Wish I knew that ahead of time also. Not sure I want to go hacking with them on. Probably should take them off, nope that sounds like a terrible idea, any recommendations on the plastic surgery tools?
Cheers..
C529579A 28C4 434C 8C80 A16EF0A62979
767E62D7 0B89 4B1B 9B70 0192024B12FA
21A62355 C555 4C2C 8671 379FB38B32D3
E562CCC8 8B75 47A7 99A8 88D81C0CA481
E3A30BBC E6ED 46A8 B449 6E3D5CFCDC74
TMCCOY
27
34
Looks great. With OEM wheel, you need 1.5" spacers to equal the track width front to rear. I run the 1.5" RB3 lightweight spacers just torquing them with no loctite and they hold just fine having checked the torque on them a number of times.
Reactions: Montecresto
5,744
26,371
That's only an inch wider per side, no biggie. Some racers use a wider track up front so it's not like you'll be breaking a 'rule'. I don't like spacers so If the look didn't bother me, I'd run the wider front end.
Reactions: BrianN
eagleXP
eagleXP
19
37
Longview
I was thinking that a bit wider in the front was good. I did not even notice it until parking it in the garage.
SLOWPOKE693
SLOWPOKE693
2,020
7,831
Somewhere in Texas
It is!
Pivoting off a rear tire that is 1.5" further inboard than the fronts helps the machine turn better. Has nothing to do with "racing" and everything to do with plain ol turning.
211,870
Cheers..
View attachment 228365View attachment 228366View attachment 228367View attachment 228368ey don't clean as well as the
I've been running the Terra Hooks for a year, good tough tire, they don't clean as well as the Black Waters, but I like them better.
Reactions: TripleB
It is!
That’s good info....👍
Cheers..
Those skids are BA. Have a link?
eagleXP
eagleXP
19
37
Longview
3D13FDDB 31B5 490C A03C 4756542B6A81
An aggressive file made quick work to round off the corners of the skid in the front.
Reactions: CID
eagleXP
eagleXP
19
37
Longview
I saw someone but 13 plugs in a tire on the trail. I decided to get 5 wheels same width and offset all the way around. What are you rolling on? Pictures plz.
eagleXP
eagleXP
19
37
Longview
I decided to leave the spare tire in the truck. Probably going to get another mount and put the sXs spare on the trailer. I know it’s not on me but I got one with me.
Reactions: TripleB
211,870
You won't need a spare with the ITP Terra Hooks.
sspeederr
sspeederr
391
661
I am running stock wheels and 32x10 rock a billys on my R to outside of treads I am only 1 in difference so that means 1/2 per side
eagleXP
eagleXP
19
37
Longview
5DA9C7F6 5679 49B4 9369 88FA5004B6EF
02912808 5483 4BA2 9223 761166811D95
this is the only problem I have had with this set of tires. I got a split with about 300 miles on one. I emailed the distributor about it, no response.
  • Wow
Reactions: TripleB and JenElio
sspeederr
sspeederr
391
661
View attachment 252901View attachment 252903
That looks more along the line of a cut from sharp rock just by looking at surrounding lugs with cuts in same general direction. I have had this happen on many sets of tires just my opinion but that’s probably y you haven’t gotten a response from distributor
eagleXP
eagleXP
19
37
Longview
100% it’s me throwing rocks on the hill climbs. My son says let’s go rip rubber. I made a t-shirt, and gave it to him. It’s amazing what you can get up on these in a 4 seater.
