Trailer lock suggestions
rocmar
rocmar
4,741
5,777
4 CORNERS
The Amplock seem to get good reviews but they are pricey -
Pot metal
...get cold
tap with hammer
it's in pieces on grnd
....but helps ..cause thieves
are LAZY...if it's too much work
...they won't take it...
...a sign sayin....
" owner don't call 911"
Might help....haha
HATE THIEVES
Reactions: ChadD and joeymt33
rocmar
rocmar
4,741
5,777
4 CORNERS
Yeah.. they're not much!
Some of the reviews of that last one didn't give me high hopes..
I've got half a mind to contact some of these different comapnies and have them send me some of each lock to do a torture test review!! I wanna know how difficult each are to pry, knock
Pull a tire.
Yeah.. I've eyeballed them. But I can make something cheaper and just as good for that $$$. Both trailers are inside now anyway... I did order 3 different locks today.
IMG 3389
Reactions: sharp
Ragnar406
Ragnar406
The Great Bald One
4,459
17,081
Bella Vista, AR
Let us know - I have a different coupler that I normally see and I can't remember the name off hand
5404f44b9455dc5b8e7a5bc475c6f535
You can see the cheap 10 sec pin lock I use in the picture (well it was not cheap) and then here is what I do on the wheels
7b7c7c788def78cc33d7a5f48fef1000
I want to add an additional lock
Tramguage1
Tramguage1
Texan
7,576
31,278
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Its a Hammer Blow or Bulldog type coupler.
Reactions: JTW and sharp
I think your in pretty good shape with a quality pin type lock, with how that particular type of hitch works. It would be much more difficult to get into than the top lever style most trailer have. Unless a smaller ball could slip in the closed hitch, that's a tough one to get in my mind.
dealer6
39
112
Hubbard
I use this one and like it, although I lost the key once and was able to cut off with battery powered sawzall
A 5# shop hammer will get one of these off pretty easy
I lost the key to mine and a few good wacks with the hammer and it came right off
Reactions: rocmar and JTW
Ragnar406
Ragnar406
The Great Bald One
4,459
17,081
Bella Vista, AR
I just figure I could take a hammer to the pin and it would break but better than nothing - then there is the wire through the wheel - I should chain the back of the trailer to a tree - so if some one does hook up and take off at least they would get a surprise :)
Reactions: JTW
I would think a good one would be pretty tough
swsebek
swsebek
2,854
5,835
pa
I could dismantle that in 5 minutes with a cordless grinder. Crack heads don't steal trailers.....It's guys who know what they want and how to cut s***......Where I live is high crime and I have cameras and Dvr and even hunting cams set up....When I leave for weekends and my Alum stays home,I use the max coupler lock among with a pad lock.....But either can be cut right off But most thieves don't bring a spare tire with them and a grinder. So lately I have removed one wheel and lay a tarp over it so you can see.and I put the tire in basement.Sounds insane but every other week thieves impress me around here.and always cover the hitch devise so they can't see what you have and keep weather off it or you will be just locking yourself out.You can have all the insurance in the world but when someone steals your stuff it just works at you
Got tired of living in "town" and in sub-divisions where this was more prominent problem because there was a high concentration of stuff to steal.
Made it harder for them to find me, see what I have if they did, and get to it. Moved out of town to a more rural area where everyone knows who you are and what you drive, then put up a gate. So if you're there and you're not supposed to be everyone remembers. Along with the 19 4K CCTV cameras that can see in no light.
My family's security and privacy is more important to me than thieves and trespassers.
Not a doomsday prepper, I acknowledge people usually will take advantage of you if you let them and in general are not to be trusted.
I have these keyed alike and use the pin lock when it's hooked up.
Doesn't stop them but with the ball locked into the truck it would slow them down long enough for me to go into a place and get food.
Locking it to the trailer is harder it can be rolled off in neutral and pulled up on another trailer.
IMG 7083
Reactions: sharp and joeymt33
Like it. I feel slightly better since I've got a second lock helping to hold the first in the have to defeat first which takes more time.
Reactions: ChadD
Ragnar406
Ragnar406
The Great Bald One
4,459
17,081
Bella Vista, AR
ok how about:
or
Thanks @misterkit I don't know if I feel encouraged to start a life of crime or go chain the axle of my trailer to a tree now lol
sure does not give a good sense of security - I would like to see the Proven industries lock tested by another group but that does look stout.
Reactions: ChadD
The keyway itself would be a weak point on that one. Could always drill it out. It's most likely brass.
But they all have keys so looks like strongest one.
Reactions: ChadD
misterkit
42
36
ny
I'm leaning towards the Proven Industries one too but I figured someone here may know a weakpoint for it....They aren't cheap either.
Amazing how easy a lot of the other ones are defeated though.
misterkit
42
36
ny
Found this as well.
