P1000 Trailering in the rain
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
I sure I am confused after reading this post. I thought the snorkel ran off of the pre-filter area directly under the hood? You just extended that area straight up.
So the snorkels are running from the radiator area under the hood?
I thought like CrowHunter that it all started directly underneath the hood where the filter is?
There are 2 different designs that I have seen. One skips the prefilter all together and comes straight into the air filter box at the back. The others go into the tube next to the prefilter area.
Once I actually went out and looked at it myself I realized I had a fundamental misconception of where the actual intake is. Water hitting the hood isn't the problem. It would be very hard for water to make it into the system this way.
The problem is splashing up UNDER the hood behind the radiator. That could get drawn directly into the system. Pretty much if you are going to be splashing into water, you need to move that intake.
322,675
Straight up but backwards. For pics sometimes I'll have it forward.
322,675
@Crow_Hunter has it right that is the deal
Reactions: Crow_Hunter
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
So if I am understanding this right, there is no reason to bother with the snorkel system that comes off of the pre-filter under the hood, that would not be the best guarantee but bypassing it completely off of the radiator would be the way to go correct?
Glad I read this when I did because as a plumber I was just going to slap a 3 inch fernco and a piece of PVC pipe and come straight up :)
Reactions: CumminsPusher
Crow_Hunter
Crow_Hunter
750
836
If it were me, I would do similar to what Joey and CP did.
It is up front where you can see it, it also doesn't bypass the tuners that are downstream (resonators) like going directly into the air box and it looks to be much easier and probably easier to put back the way it was too if you decide to change it back.
But I have absolutely zero experience snorkeling anything so asking my advice on this is extremely dangerous.:D
Plumber101010
Plumber101010
597
584
LMAO! Obviously we are both in the same boat or I wouldn't be asking the other blind person :)
322,675
Even throwing a 90deg backwards on the up pipe but staying under the hood like @Hondasxs did would be fine. The current system either your ok or your not. People could or could not be adding water all the time. It's no big deal till it is. It's too cheap and easy to snorkel. I regret not knowing I was adding water all the time. I like @joeymt33 design because I can see what's going in and I can 86 it very quickly if/when needed.
Reactions: joeymt33
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Uh, stuck in the house because it's raining? Dude that's the best time to ride!
You got that right! Daughter and I went in pouring rain for first time couple weeks ago. We were having a blast til the lightning started (and we were surrounded on all sides by trees).
