P1000 Trailering with a glass windshield
Coon
Coon
45
61
Arkansas
Going to pick up my P1000 Monday morning. My question is do I need to back it onto the trailer to bring it home? I have almost a 3 drive back.
Reactions: dotman1
CPope
CPope
352
1,152
Pulaski TN
I would pull it on forward the way the windshield is designed to face the wind. I have hauled mine with the 2 piece closed for 8hr trip running 75 mph with no problems. I would think a glass windshield would be even better.
Coon
Coon
45
61
Arkansas
Worried about rock chips. I guess I should have clarified that.
N
Nightcrawler
103
229
Portland, OR
Throw a piece of cardboard over the window w/ some duct tape.
322,690
If you're really worried get a piece of plexiglass cut bigger then the windshield drill six small holes to fit some suction cups and suction it to the factory glass. So you know it's flat glass and any glass shop can replace that glass for 150 or less. Not too big a deal
KevinSC
KevinSC
286
306
You can also put a rubber mat over it and bungee cord to place just a little cheaper ;)
Reactions: CumminsPusher
322,690
Absolutely. Just keep in mind if it does go south on you its not another 650 through Honda. It's safety glass but it's still flat. You won't need to replace the whole unit. My suggestion is just go have fun don't be too concerned. Oh and by the way anyone considering a factory glass call around to the dealers close because Honda doesn't package these well and they come in a lot broken. You can save over 300 to buy it and remember replacement is under 150
Reactions: KevinSC
AKTMW
AKTMW
82
115
Anchorage
I pull it on forward. I had a windshield cover made for mine, after my first rock chip. Wraps around the hard doors. Probably overkill but it seems to be working.
Coon
Coon
45
61
Arkansas
Can someone with a glass windshield give me the measurements of just the glass so I can make something before I leave out in the morning to get it?
Reactions: albert621
322,690
I'll check in a couple minutes if not too late already
322,690
51 1/4-22 1/2 minus the radius' is the outside rubber.
322,690
You're welcome Coon. And welcome to the site!
Reactions: Coon
Boomboom907
596
620
Washington
Im in alaska, and my local glass shop quoted me 150 without labor. just the glass cut to fit.
thats the route im going. i dont regret spending the 650 on the glass window one bit. Made in america, steel, and automotive glass. worth the money.
322,690
They would install it very cheap it's an old rope in style and lots of people if it were cut could install it. It's easy. But yes the Honda glass windshield is really good and worth it. I just mean if it breaks you don't need to buy the whole setup from Honda again. Honda doesn't build thier own glass anyway.
Coon
Coon
45
61
Arkansas
The dealer put two layers of cardboard over the glass and then wrapped it good with shrink wrap.
B95289447f073b2648759dbe27f7ec1f
322,690
That's nice they did that. Not sure if that's enough trailer though:)
Coon
Coon
45
61
Arkansas
Traded this in on it, needed the room. 2076c86b5300ca8c3bad659350740735
