has anyone noticed the difference in the transmission between 2015- 2016 being lower than a 2017
The 15/16 models didn't have auto shift, on 17 & up even if you have it in manual mode it will downshift when the ECU thinks it's necessary. I changed the final drive gears in mine.....click the link in my signature below.... it made the P5 much more fun in the trails but 1st/Rev are still low enough for work/chores.I agree, my former 2015 had a low 1st/reverse. I do not remember my 2015, automatically downshifting when riding like my 2017; that is, when you are traveling along, even in manual mode say in 5th gear, then slow down to take a turn it automatically downshifts and for my unit, it selects the right gear pretty routinely, so you only have to upshift, basically....
I want to see someone connect a tachometer and test two different year machines with the same tire size at the same speed in 1st gear.
2015/16... L,2,3,4,5Was the older machine L,1,2,3,4 and the new ones 1,2,3,4,5 ?
Interesting..... my '16 does not auto downshift, I can come to a complete stop in 5th gear. Does your's have the MT/AT switch on the dash? That didn't come until the '17 model year, maybe yours was a late '16 build.I have a 16 and it automatically downshifts when in manual mode. What I wish these things had was an overdrive.
Good catch @Mudder , I didn't catch that.He lists a P1000 on ownership?? Maybe the P1000 does.
I can easily start from 2, even after my gear mod. It will start off in 3rd but I don't recommend it.So what is the lowest gear a 15-16 will start from a dead stop? It’s 2nd on my 17.
Well...it'll start off in 5th if you like working the clutch super hard.So what is the lowest gear a 15-16 will start from a dead stop? It’s 2nd due to computer on my 17.
