P1000 Transmission whine
W
WillieBear
NC
Whining loud noise from trans or drive train. What is best oil/ lube to use?
Reactions: TxDoc and Lady01
0
0860silverado
945
1,813
louisiana
Yep. It's the straight cut gears in the sub-trans. No remedy that I know of. Can't use gear oil. It won't shift drive modes properly, if at all.
Reactions: Lady01
Ohio4x4
Ohio4x4
I brought the dishwasher
1,494
15,022
I just switched to 0-40 mobile 1 full synthetic. It's made for European air cooled cars. So far it's the heaviest oil I've found that will allow the sub trans to shift when cold. We rode about 250 miles last week and had no issues with shifting to low gear like I had with the 10-40 when cold.
Major0887
Major0887
30
60
Arizona
Been running this for about 100 miles. Shift better then it did with 10-30. Plus it’s a lot quieter then it was. It’s got the Viscosity of ATF with the protection in 75-90 gear oil.
toddvdh
toddvdh
1,066
6,991
Green Bay, WI
Is it a new noise?
How many miles?
Did you check the oil level?
Have you done service recently?
Reactions: Lady01
56,731
You get some grinding when it was cold? Mine did that a couple times over the last couple years and it gave up the ghost out of the blue on the last ride I was on. Check your cable (under the main battery and little splash cover), hopefully it's just a tad stretched and getting it back in spec coupled with the synthetic prevents it from going kaboom.
Reactions: Lady01
Ohio4x4
Ohio4x4
1,494
15,022
Its usually been my lack of patience when it grinds but I'll check it when I pull the buggy apart this week to get ready for the takeover.
Reactions: Lady01 and Adam490
W
WillieBear
NC
Is it a new noise?
How many miles?
1,000 miles, noise not knew just seems louder. Doing service now and asking what’s best oil to put in other than Honda G4.
Reactions: Lady01
toddvdh
toddvdh
1,066
6,991
Green Bay, WI
I use 10w-40 in all my stuff. Whatever is cheapest at Walmart.
have you checked the fluid in the sub transmission? I changed all 3 drain plugs last time and it made my shifts and driving noise quieter.
Reactions: Lady01
5,029
22,476
The gear whine in all 3 Talons I’ve spent time in has been bad enough that I won’t ride without earplugs (inside my helmet). Hearing loss is permanent and progressive - since it doesn’t hurt we ignore it until it‘s too late - tinnitus 24/7 for me.
