Transporting Your New Honda Pioneer
208,730
Is It a good idea to use your winch along with the straps?
Dosen't the P5's have a E brake? I installed a Delton E brake and it trailers great with straps, no rocking.
Reactions: Russ989
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
depends on how you load it and the trailer. i i have pipe trailer and a warn 4000 . i just pull up to the bars hook my winch up to the cross bar on the tongue. pull ut down add straps tap off a littlet on winch then tight my back straps to frame as close as i can to the a arm angles and a little distance. dont use winch alone. i use pull straps instead of ratchet. but they are only for the bike
tincangob
tincangob
200
270
Central Wisconsin
I strap at the a arms instead of the front bumper and rear cage. No suspension movement to loosen straps that way. Take notice where rollback wrecker drivers put their chains, same reasoning.
I have tied down both ways, but this is indeed the "proper" way for exactly the reason you mentioned. I think the Honda Owner's Manual instructs you to tie down on the "A" arms also, but their pictures are not very clear. I also think the manual says to have the transmission in 4WD lock with brakes on. I always check my tie downs after I drive 5 or 10 miles just to make sure everything remains secure, and frequently you can tighten things up a bit.
BigOL3
BigOL3
2,994
8,920
I load mine in turf mode, put it in PARK, use 4 rackets straps BELOW the suspension, not above on bumpers, pulled tight in opposite angles. Never had ANY problems
hondabob64
hondabob64
215
795
Louisiana
Most secure way of transporting your side by side. Rock solid & lockable on your trailer. My hunting partner Danny Weaver invented & patented the LA Guard Dog & Trailer Dog. If you’re interested, go to www.laguarddog.com
953F7CCB BF22 4953 A1FF A3796AD17A11
Tramguage1
Tramguage1
Texan
7,500
30,749
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Heres how I do it now.
A strap through all 4 wheels and then ratchet straps.trans in neutral
20190428 061003
Bonefrog
Bonefrog
5
7
PA
Great tips, I had a ratchet strap come loose and was dragged for about hour; I thought the honking was for what a great looking Honda
hurld
hurld
129
159
I just installed this setup on my trailer at all 4 wheels, lets the suspension move on rough roads & is super quick to load strap & go. I should have done it a long time ago.....Bb417aac49e29acc849ee9801e5585f7D973aee12282689c4c541d5fc96776eaA174406de935c8d377ef5f32421ed680Bd169199ad9496e1cf980c20199bfdc6
Sent from my SM-N960U using Tapatalk
Russ989
Russ989
22,642
147,257
Reactions: hurld
tincangob
tincangob
200
270
Central Wisconsin
I do like the fixed blocks so you don't have to guess if the machine is too far forward or not. I have an aluminum trailer and sort of hate to drill the holes required, and so I've been using 4 ratchet straps attached on the frame near each tire. I also do not have a tail gate of any kind on my tilt trailer, and I would sleep better if I somehow blocked the machine in the event of a total failure of the tie downs. The trailer is really nice, a bit pricey, with hydraulics so you just drive on or off w/o a ramp (Aluma I think). Really quick and by far the best trailer I've ever owned - have 3.
It is sure worth the effort to think through how to secure the machine on the trailer.... still thinking. LOL
All the input is an education. Thanks
(BTW, I recently removed the doors on my P1000-3 which really helped a lot with the heat problem for the summer.)
BigOL3
BigOL3
2,994
8,920
I just installed this setup on my trailer at all 4 wheels, lets the suspension move on rough roads & is super quick to load strap & go. I should have done it a long time ago.....View attachment 148161View attachment 148162View attachment 148163View attachment 148164
No doubt that setup HOLDS very well, but it is not for me for several reasons.
My Pioneer can not always ride in the same position. Sometimes it is by itself, other times with ATV or other gear. Also I do not wish to waste time getting 4 wheels in the EXACT spot. I prefer not having to worry if it is an inch or two too far/short, or too right/left.
Reactions: Fischer and hurld
Fixing to see what this whole wheel bonnet talk is all about. Got the L track finished up and headed to Moab in a week! We shall see if the hype is all that.
CBEFDA18 A888 401F 9609 6FA0510B7E82
A7D6F4F3 26F2 41F0 9635 B3EBB0ECA431
Reactions: Ragnar406
